Using BibTEX
  • Thread starter NoobixCube
Main Question or Discussion Point
Hey all,
My bibliography is not showing up in the PDF output, and I'm not sure why..
The bib file is in the same directory as the the main tex file.
I am using the command:
\documentclass[a4paper,twoside,11pt]{book}
\usepackage{calc}
\usepackage{setspace}
\usepackage{graphicx}
\graphicspath{{TwoBody/}{StatAn/}{OrbitalInc/}{OrbitalFam/}{Future/}{FeasandApp/}{DetectingExo/}{Conclu/}}
\usepackage{amsmath}
\usepackage{epstopdf}
\usepackage{helvet}
%%%%%%% Page styles %%%%%%%
\setlength{\hoffset}{-1in} \setlength{\oddsidemargin}{40mm} \setlength{\evensidemargin}{30mm}
\setlength{\textwidth}{\paperwidth-\oddsidemargin-\evensidemargin} \onehalfspacing
%%%%%%% Document starts here
\begin{document}
%whole bunch of of chapters in here that compile fine!
%%%%%%% Bibliography %%%%%%%
\bibliographystyle{plain}
\bibliography{mybiblio}
\end{document}
Any help would be really really helpful!
Answers and Replies
Have you run BibTeX against your document yet? A full compile cycle for a document with a BibTeX bibliography looks something like this:
Code:
latex mydocument
bibtex mydocument
latex mydocument
latex mydocument
If I recall correctly, the first invocation of latex creates mydocument.aux, which is read by BibTeX to find the appropriate bibliography style file (.bst) and the appropriate bibliographic database(s) (.bib), which it uses to produce a bibliography (.bbl). The second invocation of latex incorporates this bibliography into the output, and the third and final invocation of latex updates all of the cross references.
So what I gather is you want me to compile the document 3 times?
I am using Winedt, PDFtexify compile. Does this help.
After a number of times compiling the document, only the first BibTex reference is displayed in the final PDF (I guess it's a start) but the other reference which are cited with the document are cited as: [?]
and they do not show up in the bibliography.
f95toli
492
Is bibtex giving you any errors? It sounds like there is a problem with your bibtext file, probably an extra } or something similar that is terminating the file early.
Try running bibtex from a DOS prompt, that way you can see any errrors more easily.
How would you go about doing that ?
I have uploaded my Bib file, hope this helps.
I had to save the file as .txt because it didn't accept .bib extension
Related Threads on Using BibTEX
  • Last Post
75K
  • Last Post
  • Last Post
  • Last Post
