lampshader
- 39
Using Ohm’s Law as a check: V = IR, where V = emf in loop, what is the ratio of the current in the loop of radius 20 cm compared to the loop of radius 40 cm?
(It should be the same as the ratio of the emfs!) Treat the loop as a solid circle and remember the formula for the area of a circle is A = π r2. So if the radius is halved, what does this do to the area? Does this agree with the ratio of the two peak voltages that you calculated? Record your observations and explain.
V = IR,
m = (y2-y1) / (x2-x1)
I gathered all my data (which is the first part of the question):
Table 1:
Loop Radius (cm) Peak Voltage (V)
10 0.138
20 0.553
30 1.244
40 2.211
50 3.454
The data in table 1 is suggesting that as the radius increases, so will the peak voltage.
So my instructor wants me to check it using Ohm's Law, How exactly would I do that? Here is the question again:
We have:
I = V / R = 0.553 / 20 = 0.27650;
And:
I = V / R = 2.211 / 40 = 0.55275;
My instructor is saying that it should be the same as the ratio of the emf's
