Creating a Temporary Vacuum: Is it Possible?
  • Thread starter dizam
  • Tags
    Vacuum
In summary, the conversation discusses the possibility of creating a vacuum around an object by destroying all the air around it. It is concluded that if the object is not inside an enclosure, air would immediately come in. However, it is also mentioned that the air may not be able to come in faster than the speed of sound. The conversation also mentions a similar phenomenon that creates thunder. It is suggested that a supercavitation type of phenomenon may be possible with a vacuum. It is also mentioned that the object's acceleration may affect the airflow, but the exact impact is unknown.
dizam
If you were to destroy all the air around an object, would that give you a temporary vacuum or would the air be replaced so quickly that it wouldn't make a difference?
Is the object inside an enclosure? If not, air would come in immediately.
Well it couldn't come in faster than the speed of sound.
Something pretty similair happens to make thunder
No, the object is not inside an enclosure. I was thinking of any type of sealed object traveling through the sky.
Are you certain that this is true? Could you explain the logic please? So then a supercavitation type of phenomenon would be possible but with a vacuum.
Would you mind elaborating please. Thanks
Also, let's say that the object has acceleration. I know this would affect the airflow but how?
1. Can a temporary vacuum be created?
Yes, a temporary vacuum can be created. A vacuum is an area with no particles, and while it may be difficult to achieve a perfect vacuum, it is possible to create a space with a significantly lower density of particles.
2. How is a temporary vacuum created?
A temporary vacuum can be created by removing the particles in a specific space. This can be done through various methods such as using a pump to suck out the air or using a container to trap the particles in a smaller area.
3. What is the purpose of creating a temporary vacuum?
The purpose of creating a temporary vacuum is to study the behavior of particles in a low-pressure environment. This can help with understanding the properties of different materials and how they interact with each other.
4. Is it safe to create a temporary vacuum?
It can be safe to create a temporary vacuum, but precautions should be taken to ensure the safety of the people and equipment involved. Careful planning and appropriate safety measures should be in place to prevent any accidents or damage.
5. How long can a temporary vacuum last?
The duration of a temporary vacuum depends on the method used to create it and the conditions in the surrounding environment. It can range from a few seconds to several hours. Eventually, the vacuum will be filled with particles again through diffusion or other forces.
  • Classical Physics
  • Other Physics Topics
