Homework Help: Values of concavity. Please help!
  1. Nov 9, 2008 #1
    For what intervals is g(x) = 1/(x^2+1) concave down?
    2. Relevant equations
    Quotient Rule
    3. The attempt at a solution
    OK, so I have found the first and second derivative, but I am confused as to how I should use them to find where the function is concave down. Do I set the second derivative equal to zero? Use the quadratic formula? I know the answer from the back of the book, but my attemps to get the same answer have failed. Please point me in the right direction! Thank you :)
  3. Nov 9, 2008 #2
    gabbagabbahey
    Setting the second derivative equal to zero will give you the inflection points, but you also need to determine whether the second derivative is (+) or (-) on each side of these inflection points....what are you getting for your solution?
  4. Nov 9, 2008 #3
    Ok, so for the 1st derivative I have:
    -2x/(x^2+1)^2
    Second:
    -6x^2-2/ (x^2+1)^2
    Do I need to factor the denom? Also, you stated that I need to determine the values on either side of the inflection points, I should do that with my calculator, right? So, if I have this correct, determining the value (+ or -) of the function on both sides of the inflection points will tell if the original funtion is concave up or down?
    Thank you!
  5. Nov 9, 2008 #4
    gabbagabbahey
    Close, I get the numerator as being +6x^2-2... and you don't need to factor the denominator; the expression will only be zero when the numerator is zero....what does that give you for you inflection points?
  6. Nov 9, 2008 #5
    WOW! You have been so much help!
    I got
    X= sqrt of (1/3)
    So the function is concave down for all X values between -< X < + of sqrt (1/3)
    I have been going crazy trying to figure this is out! Thank you for your time :)
  7. Nov 9, 2008 #6
    gabbagabbahey
    No problem :smile:
