Umhh.. I'm a pretty newbie on this.. But I'm trying to build a working Vandegraaf generator from legos.
So, the basic idea is that I build high pipe from legos, and then use lego-motor which makes two rods rotate. The second rod is on the top and the second one is on the bottom. They're covered by lego-car-tires (something soft-rubber/plastic) and a belt runs with them as the rods rotate.
Then there is two combs, made by foil, both near the rods and tires. One on thr top and other one on the bottom. Then there is foil sphere on top of that thing. So.. Umhh.. And the bottom comb is connected to the ground.
Could this thing really work? And what I should use as belt? And are the rods (rollers) and combs ok?
Picture of it:
Picture of it:
Code:
_____
| | Sphere
\_____/
-|=#=|- Upper rod/tires
| # | #=belt
| # | %=comb
Motor | # |
|__|--|=#=|- Lower rod/tires, with motor
