Vaporize dangerous asteroid
  • Thread starter GTOM
47
Lets suppose a space station is threatened by a meteor or some kind of space debris, and the station couldnt be moved fast enough. Could lasers, or particle beams become a realistic solution for that situation in not so far future?
It talked about a GJ power, although i am not sure it is credible enough.
Lets suppose we have only 10 MJ. If i calculate correctly 10 MJ is enough to vaporize 1kg of titanium in vacuum.
Could be the vapor, or melted metal still dangerous, or would it disperse fast enough? Or redirect the dangerous object with steam pressure?
33,379
9,103
Liquid vs. solid doesn't make a difference for an impact, but vapor will spread out really fast and won't be a threat.
You get a bit of propulsion from ablating the surface, but doing that in a directed way will be very challenging.
etudiant
110
All depends on how much of a nudge is needed.
A pebble is a lot different from a boulder or from a mountain, yet if one can apply the nudge early enough, a miss can be achieved even with just a small impulse.
Iirc, NASA has proposed diverting potentially hazardous bodies simply by having a diversionary spacecraft fly near it and shift the trajectory by its gravitational pull. The challenge is to find the hazardous items early enough that one can try to deal with them without dubious brute force methods.
tech99
549
What about the equal and opposite reaction on the space station?
812
47
The station has bigger mass and better cooling.
73
Is it also possible to impact the asteroid with large railguns? Even the asteroid isn’t obliterated, it still passes a lot of kinetic energy to the asteroid, thus changing its trajectory.
Actually, if we can harvest the resources of the incoming asteroid, it is a mountain of precious metals and minerals, including things that are very rare on earth... in this case, we pull the asteroid to orbit around earth, and mine the resources on it. It also saves delta-V to redirect an incoming asteroid towards earth than seeking them in deep space or asteroid belt...
tech99
549
Are you sure you want to do this? If you had vapourised the asteroid which created the Chicxulub crater 66 million years ago you would have stopped the descent of man.
Want to reply to this thread?
"Vaporize dangerous asteroid" You must log in or register to reply here.
Related Threads for: Vaporize dangerous asteroid
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
