Homework Help: Variable mass dust particle
  1. Apr 19, 2014 #1
    At time t=0 a dust particle of mass m_0 starts to fall from rest through a cloud. Its mass grows exponentially with the distance fallen, so that after falling through a distance x its mass is m_0exp[αx] where α is constant. Show that at time t the velocity of the particle is given by:
    v=sqrt(g/α)tanh(t(sqrt(αg))
    2. Relevant equations
    Variable mass equation:
    mg= mv'+vm'
    3. The attempt at a solution
    Using the variable mass equation i've fiddled around with it and gotten out a differential equation in terms of v, which is:
    dv/dt=-αv^2+g
    Which after filling in the answer im looking for is the correct equation. However solving it properly by hand seems harder as its a non-linear ODE. I was just wondering is there any other way of going about this problem or if not, can anyone give me a tip on how to solve the ODE properly.
    Thank you for your time
  3. Apr 19, 2014 #2
    TSny
    2017 Award
    Hello, Matt_993. Welcome to PF!
    Did you mistype this? What does the symbol y stand for?
    Once you get the equation written in terms of just 2 variables, you might try the technique of separation of variables.
  4. Apr 19, 2014 #3
    Yea the y should've been a v, I've changed it. But I can't seem to be able to separate the variables in the equation because of g, is there another way?
  5. Apr 19, 2014 #4
    TSny
    2017 Award
    Divide both sides of the equation by the entire right hand side.
  6. Apr 19, 2014 #5
    How very stupid of me, can't believe I missed that.
    That works, thanks for the help :)
Have something to add?
Draft saved Draft deleted
Loading...
