Variable name matlab help
  1. Oct 2, 2009 #1
    URGENT variable name matlab help
    How do i change the variable, so it saves all the values, even if it must happen for 6 different variables name. This is because when i run it, it only saves the values for v_max when n=10 as this is the last iteration. How can i make all the values be saved. My coding is below:
    radius=1:0.5:2.5;
    total_flow_velocity=5
    for n=5:1:10
    v_max = (total_flow_velocity.*(1+n).*(1+(2.*n)))./((2.*pi)*((radius.*n).^2))
    end
    Thanks
  3. Oct 2, 2009 #2
    Re: URGENT variable name matlab help
    probably the best way is to store them in a vector. You define a vector called v_max with a length equal to the amout of values, in your case that is 6:
    v_max=[1:6];
    then you can store each value in one of the positions of the maxtrix like:
    for n=5:1:10
    v_max(1,n-4) = (total_flow_velocity.*(1+n).*(1+(2.*n)))./((2.*pi)*((radius.*n).^2))
    end
    I used n-4 to define column number 1 because you start with n=5. After that you can recall any value by typing:
    v_max(1,1) .... v_max(1,6)
    good luck!
  4. Oct 2, 2009 #3
    ive tried it but i get the error "Subscripted assignment dimension mismatch." ? Also why did u do vmax=[1:6] because for each r value ive made it so i get an answer at each n value, so shouldnt the matrix be a 6x4?
  5. Oct 2, 2009 #4
    JeroenS' code has a mistake inside for loop. v_max(1,n-4) ==> indicate member (1, n-4) of array v_max. However, in the calculation, he forgot to delete the operator for array: (radius.*n). This operator (.*) will return an array radius multipled by n. So, in the left-side, you have 1 variable, not an array but in right side, there is an array. That's the reason matlab throws an error.
    My code is:
    Code (Text):
    vM = [];
    j = 0;
    radius = 1 : 0.5 : 2.5;
    tfv = 5;
    for n = 5 : 1 : 10
        j = j + 1;
        nR = 2 * pi * (radius * n).^2;
        vM(j, :) = (1 + n) * (1 + 2*n) * tfv ./ nR;
    end
    Hope this help.
    p/s: i am totally confused when i read your code. There are many unnecessary parentheses and operators.
  6. Oct 2, 2009 #5
    Thanks so much, yeh i don't know why i use so many brackets and that, buts it because im use to the calculator and have only been learning MATLAB for a few weeks now :P but im beginning to learn to use less brackets :P
Loading...
