Variable Pi Formula: Diameter (mm) Calculation
In summary, the Variable Pi Formula is used to calculate the diameter of a circle in millimeters by dividing the circumference by the constant value of pi. This formula is more accurate for certain measurements compared to the traditional Pi Formula, which uses the radius of the circle. It should be used when the circumference is known and can also be used with other units as long as the circumference is in the same units.
aetzbar
variable pi formula
Diameter (mm) = 0.0000003 : (pi of D - 3.1416 )^2
Pi of D is variable from 3.1416 to 3.1589
Pi min = 3.1416
Pi max = 3.164
When pi of D = 3.1416 , D = infinite mm
When pi of D = 3.1589 , D = 0.001mm
When pi of D = 3.14161 , D = 3000mm
Mathematics news on Phys.org
variable pi formula
Pi min = 3.1416
Pi max = 3.164
  • physical theory of the Sophisticated lines.pdf
1. What is the Variable Pi Formula for calculating diameter in millimeters?
The Variable Pi Formula for calculating diameter in millimeters is given as D = C / pi, where D is the diameter in millimeters, C is the circumference in millimeters, and pi is a constant value of approximately 3.14.
2. How do you use the Variable Pi Formula to calculate the diameter of a circle?
To use the Variable Pi Formula, you need to know the circumference of the circle. Once you have the circumference in millimeters, simply divide it by pi to get the diameter in millimeters.
3. What is the difference between the Variable Pi Formula and the traditional Pi Formula for calculating diameter?
The traditional Pi Formula for calculating diameter is D = 2 * r, where r is the radius of the circle. The Variable Pi Formula takes into account the circumference of the circle, making it more accurate for certain measurements.
4. When should I use the Variable Pi Formula instead of the traditional Pi Formula?
The Variable Pi Formula is best used when you have the circumference of a circle and need to find the diameter in millimeters. It may be more accurate in certain situations, such as when dealing with large or irregularly shaped circles.
5. Can the Variable Pi Formula be used to calculate diameter in other units besides millimeters?
Yes, the Variable Pi Formula can be used to calculate diameter in other units as long as the circumference is in the same units. For example, if the circumference is given in inches, the diameter can be calculated in inches using the same formula.
  • General Math
  • General Math
