Variable pressure
I need to introduce variable pressure into a system. I was planning on using piston pumps which if i run at low rpms would result in controlled fluctuating pressures. Am i doing something wrong?
russ_watters
Mentor
18,060
4,576
We need an awful lot more information about the system and its requirements. Do you have a diagram? What is the purpose? What are the flow rates and pressures? What design constraints do you have? Why are you using a piston pump?
I am working on an experiment where i would like to see how the system responds to pressure fluctuations.
I tried using a stepper motor and a cam arrangement to create pulses in the pipe carrying water to the system. However, I can't get higher frequencies of pressure oscillations.
I have flow rates in the range of 0.01 to 0.09 ml / min. I have a syringe pump to take care of that. However, I am unable to figure out how to introduce pressure oscillations into the system.
That is when i thought a piston pump working at low rpm may do the trick. The pressure need not be fixed, but should be consistent.
Hope this info is more adequate.
Thanks
D
drankin
Thanks
What kind of pressures are we talking? Is this a water or oil system?
Q_Goest
39
What frequency of pulsation do you need? Can you create the pulsations using a valve? All you would need is a valve capable of acting fast enough, then open/close the valve quickly to get a pressure pulse.
Want to reply to this thread?
"Variable pressure" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Top Threads
