Variation of parameters
In summary: So the method of variation of parameters is a way to find a general solution to an equation by letting the arbitrary constants in the solution to the homogeneous equation be functions of the independent variable.
Hammie
111
I'm not currently in a class, but I'm doing this for fun.. but technically I would still call it coursework, so I'm posting it here..
I'm studying Redheffer/Sokolnikoff's Mathmatics of Modern Engineering.. and I find a problem on page 75, use the method of variation of parameters to find the solution of this equation:
Y` + 3Y = X^3
this one is easy enough to find the forced response by plugging in
Y= AX^3 + BX^2 + CX + D = X^3, and equating the coefficients.
The coefficients turn out to be A=1/3, B=-1/3, C=-2/9, D=-2/27.
This is the answer, but that's not my problem.
The variation of parameter method discussed in this section requires two linearly independant solutions to the homogenous equation,, of which I can only find one:
Y= Ke^(-3t).
Of course there is the trivial solution, but that would make the Wronksian in the denominator of the integrals zero.
For the life of me, I can't see how in the world one can use the variation of parameters method to solve this..
Is it perhaps a trick question? I'd email Sokolnikoff.. but he's long since left the world..
:cry:
any ideas?
In the method of variation of parameters you let the constant(s) of integration be functions of the independent variable. In this case there is only one such constant (since it's a first order D.E.), so let y(x)=K(x)exp(-3x).
Now plug it in your differential equation and solve for K.
This is what this section is calling the method of variation of parameters:
[tex]Y(t) = -y_1 \int \frac{y_2 f}{W(y_1,y_2)}dt + y_2\int\frac{y_1 f}{W(y_1,y_2)}dt[/tex]
What I'm trying to figure out.. is this asking for something that cannot be done?
You still need two linearly independent solutions Y1 and Y2 to the homogenous equation, along with only the forcing function f for it to work. In this problem, f = x^3.
I am beginning to think that putting a first order DE in this problem set was a mistake..
Well, can't say that expression looks familiar...
But you won't be able to find two linearly independent solutions to the homogeneous equation. There's only one, since it's first order and you found it: Kexp(-3x)
Variation of parameters is where you t let the arbitrary constants in the solution to the homogeneous equation be functions of the independent variable in order to find the general solution.
Did a search and found this. So it's the same thing, but your expression only works for 2nd-order equations. My advice: just let y(x)=K(x)exp(-3x) and plug it in the equation. It'll work out perfectly, but you'll be solving an annoying integral with lots of integration by parts.
right. That's kind of the point.. in this particular book, I just couldn't figure why it was asking me to compute a driven response with two linearly independent solutions to the homogenous equation, when I could only come up with one solution.
your reference shows the same thing, this method is for second order equations.
That may be a common thing in these old books.. it was published in 1958..
"do so and so"
answer is, "can't do it that way.."
:biggrin:
If that was really a first order equation : Y'+3Y= x3
rather than a second order equation, Y"+ 3y= x3, then there are not two independent solutions!
But "variation of parameters" works for any degree linear equation. The formula you wrote is just the result of substuting y= K(x)Y1 + L(x)Y2[/sup] (Y1 and Y2 are solutions to the homogeneous equation). In the first order case it reduces to what Galileo said: Let y= K(x)e-3x and substitute into the equation. You will get a simple equation for K'.
1. What is the variation of parameters method?
The variation of parameters method is a technique used to solve inhomogeneous linear differential equations. It involves finding a particular solution by varying the arbitrary constants in the general solution of the corresponding homogeneous equation.
2. When is the variation of parameters method used?
The variation of parameters method is used when solving inhomogeneous linear differential equations with non-constant coefficients. It is particularly useful when the method of undetermined coefficients is not applicable.
3. How does the variation of parameters method work?
The variation of parameters method involves finding a particular solution by replacing the arbitrary constants in the general solution of the corresponding homogeneous equation with functions of the independent variable. These functions are then determined by substituting them into the original equation and solving for their coefficients.
4. Are there any limitations to the variation of parameters method?
One limitation of the variation of parameters method is that it can only be used for linear differential equations. It also requires the general solution of the corresponding homogeneous equation to be known, which may not always be the case.
5. Can the variation of parameters method be used for higher-order differential equations?
Yes, the variation of parameters method can be extended to higher-order differential equations. However, the process becomes more complex as the order of the equation increases.
