Homework Help: Variational calculus
  1. Oct 18, 2007 #1
    I am trying to find a geodesic with Euler-Lagrange equation by varying the function
    [tex] ds/d\tau = \sqrt{\dot{x} + \dot{y}} [/tex]
    EDIT: it should be [tex] ds/d\tau = \sqrt{\dot{x}^2 + \dot{y}^2} [/tex]
    where tau is a parametrization and the dot means a tau derivative.
    However, when I plug that into the EL equation for either x or y, I get:
    [tex] (\dot{x} + \dot{y})^{3/2}(\ddot{x}+\ddot{y})=0 [/tex]
    How do I get a line from that?
    2. Relevant equations
    3. The attempt at a solution
  3. Oct 18, 2007 #2
    I'm don't know much about variational calculus, but as far as geodesics go, why does it have to be a line?
  4. Oct 18, 2007 #3
    Because the closest distance between 2 points in R^n is and the ds I am using is the differential line element in R^n.
    In R^2 the differential line element is: ds = sqrt(dx^2+dy^2)
    I just divided both sides by the parameter dtau to get the first equation in my last post.
  5. Oct 18, 2007 #4
    dynamicsolo
    If I'm understanding what you're saying, shouldn't you get
    [tex] ds/d\tau = \sqrt{\dot{x}^{2} + \dot{y}^{2}} [/tex] ?
    Otherwise, the expression you had isn't even correct dimensionally...
  6. Oct 18, 2007 #5
    Yes, that was foolish. But i had it correctly in my calculations so my question remains unanswered
  7. Oct 19, 2007 #6
    dynamicsolo
    Lemme see if I remember how this goes...
    Your equation
    implies that either
    [tex] (\dot{x} + \dot{y})^{3/2}=0 [/tex] or [tex] (\ddot{x}+\ddot{y})=0 [/tex].
    For the first term to be zero, you'd need
    [tex] \dot{x} = - \dot{y}[/tex], which would give you dy/dx = -1 , no?
    For the second term to be zero, you'd have
    [tex] \ddot{x} = -\ddot{y} [/tex] , which takes more antidifferentiation, but I believe also leads to a linear solution. (Not very rigorous, to be sure, but I believe that's basically how the argument runs.)
  8. Oct 19, 2007 #7
    That's rigorous enough for me. Its kind of weird we have that -1 solution though. Did you check that my equation is correct?
