stunner5000pt
- 1,461
- 2
Consider systems described by Lagrangians
[tex] L_{1} = \frac{1}{2} m\dot{x}^2 [/tex]
[tex] L_{2} = \frac{1}{2} m\dot{x}^2 - a \dot{x} x [/tex]
when [tex] \dot{x} = \frac{dx}{dt} [/tex] and a is a constnat
a) Derive the momenta conjugate to x for each system and write down the coressponding hamiltonians. Are the hamiltonians constants of motion and why?
Momenta conjugate to x (not familiar with the term conjugate)... does this mean
[tex] p_{x} = \frac{\partial L}{\partial x} [/tex]
but isn't the momentum
[tex] p_{\dot{x}} = \frac{\partial L}{\partial \dot{x}} [/tex]
b) Obtain the Lagrange equations of motion for each system, work out their solutions and explain what htey represent.
simply using the Euler Lagrange equation
for L1
let x = x(t)
[tex] \frac{\partial L}{\partial x} - \frac{d}{dt} \frac{\partial L}{\partial \dot{x}} = 0 [/tex]
but dL/dx = 0 so the second term is zero
[tex] \frac{d}{dt} \frac{\partial L}{\partial \dot{x}} = 0 [/tex]
dL/dx dot is mx dot so
[tex] \frac{d}{dt} m \dot{x} = 0 [/tex]
intengrate both sides wrt t
[tex] m x(t) = C_{1}t + C_{2} [/tex]
so far so good?
for L2
[tex] \frac{\partial L}{\partial x} = -a\dot{x} [/tex]
[tex] \frac{\partial L}{\partial \dot{x}} = m \dot{x} - ax [/tex]
[tex] \frac{d}{dt} \frac{\partial L}{\partial \dot{x}} = m \ddot{x} - a \dot{x} [/tex]
Into Euler Lagrange
[tex] -a\dot{x} - (m\ddot{x} - a\dot{x}) = 0 [/tex]
[tex] m\ddot{x} = 0 [/tex]
smae solution as L1 above
i suspect i made some mistake in L2. In any case they are the same trajectories. They represent straight lines?
c) Show taht
[tex] L_{2} = L_{1} + \frac{d}{dt} F(x,\dot{x}) [/tex]
and find the function F. What does this imply above the actions
[tex] A_{i} = \int_{t_{1}}^{t_{2}} L_{l} dt [/tex]
and how does this relate to your results of b)?
well that's easy
[tex] \frac{d}{dt} F(x,\dot{x}) = -\int ax \dot{x} dt = -\frac{a x^2}{2} [/tex]
the action for L2 is
[tex] A_{i} = \int_{t_{1}}^{t_{2}} L_{2} dt = \int_{t_{1}}^{t_{2}} \frac{1}{2} m \dot{x}^2 + \int_{t_{1}}^{t_{2}} \frac{-ax^2}{2} dt [/tex]
not quite sure how to proceed from here... WOuld i use the solutions from b to solve the action for each lagrangian?
for L1
let x = x(t)
so far so good?
for L2
Into Euler Lagrange
c) Show taht
well that's easy
