• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Varying Force Problem
  • Thread starter Xamfy19
1. Homework Statement
An object of mass m=1.0kg experiences a force of the following mathematical form,
F(t)=k*e^(-c*t) i
where k=6.0N and c=0.10 (1/s) and i indicates the unit vector in the x-direction.At time t=0, the object has a velocity of v=2.0 m/s and is at the origin. Where is this object after 20 seconds?
2. Homework Equations
F=ma.. maybe..
3. The Attempt at a Solution
I used the force equation and F=ma to get the acceleration and was going to use the x=(vo)t +(1/2a)t^2 equation, but then I realized that doesn't make sense... I'm kind of confused though... How do you find the distance if the force varies? Thanks in advance.
Once you've found the acceleration, as you say, use the most general form of the equations between acceleration, velocity and displacement to find the displacement for this case.
Dorothy
66
You should use the Newton's second law in this form
[tex]F = m\frac{dv}{dt}[/tex]
Then you find [tex]v[/tex] as a function of time [tex]t[/tex].
Remember that [tex]dx = vdt[/tex].
Calculate [tex]\int_0^{20}dx[/tex] to find the answer.
Related Threads for: Varying Force Problem
16K
11K
  • Posted
  • Posted
