VB code question
  1. Nov 19, 2008 #1
    Hey. This is what I have to do:
    Fix the IF conditions inside the DO loop to handle ALL possible combinations of first name and last name searches (it is missing at least one right now) and see if you can make the code more efficient.
    Dim searchFname As String, searchLname As String
    Type Employee
    Fname As String
    Lname As String
    Manager As String
    Office As String
    Phone As String
    Hired As String
    Salary As Single
    End Type
    Dim inEmp As Employee
    Dim fuzzyFirst As Boolean, fuzzyLast As Boolean
    Dim found As Boolean
    fuzzyFirst = False
    fuzzyLast = False
    found = False
    FileOpen(1, "Employee")
    'Get data
    If txtFname.Text = "" And txtLname.Text = "" Then
    MsgBox ("Please provide search criteria")
    Else
    If txtFname.Text <> "" Then searchFname = txtFname.Text
    If txtLname.Text <> "" Then searchLname = txtLname.Text
    'Determine if fuzzy search
    If InStr(searchFname, "*") > 0 Then
    fuzzyFirst = True
    'Reset search name
    If Left(searchFname, 1) = "*" Then searchFname = Mid(searchFname, 2)
    If Right(searchFname, 1) = "*" Then searchFname = Left(searchFname, Len(searchFname) - 1)
    End If
    If InStr(searchLname, "*") > 0 Then
    fuzzyLast = True
    'Reset search name
    If Left(searchLname, 1) = "*" Then searchLname = Mid(searchLname, 2)
    If Right(searchLname, 1) = "*" Then searchLname = Left(searchLname, Len(searchLname) - 1)
    End If
    'Loop through file
    Do Until (EOF(1) Or found = True)
    FileGet(1, inEmp)
    'search first name
    If fuzzyFirst Then
    If InStr(inEmp.Fname, searchFname) > 0 Then found = True
    Else
    If inEmp.Fname = searchFname Then found = True
    End If
    'Check last name
    If found And searchLname <> "" Then
    If fuzzyLast Then
    If InStr(inEmp.Lname, searchLname) = 0 Then found = False
    Else
    inEmp.Lname <> searchLname then found = False
    End If
    End If
    If found = False Then
    'check last name
    If fuzzyLast Then
    If InStr(inEmp.Lname, searchLname) > 0 Then found = True
    Else
    inEmp.Lname = searchLname then found = true
    End If
    End If
    Loop
    If found Then
    'Set output text boxes
    txtManager.Text = inEmp.Manager
    txtDOH.Text = inEmp.Hired
    txtSalary.Text = FormatCurrency(inEmp.Salary)
    Else
    MsgBox("There are no employees with that name")
    End If
    End If
    Me.Refresh()
    End If
    FileClose(1)
  3. Dec 1, 2008 #2
    I apologize for the long wait for a response, but I only recently joined this message board.
    My first request to you would be to mention any pre-created form objects in your original post, because the first time you meander through the code it looks a little confusing. The second would be to mention what version of VB your using. Be it VB6 (or VBA) ,which I'm thinking this is by your use of Left not LSet,or .Net X.X. Also, code tags make the code easier to read.
    To answer some of your questions:
    You're doing two string compares on the same information, do one and call it good. Obviously, don't take my following example as the correct answer, but this is what I would do:
    Code (Text):
    Type Employee
        Fname As String
        Lname As String
        Manager As String
        Office As String
        Phone As String
        Hired As String
        Salary As Single
    End Type
    Public Sub SetEmpInformation()
        fuzzyFirst = False
        fuzzyLast = False
        found = False
        'Get data
            Exit Sub
        End If
            fuzzyFirst = True
            'Reset search name
        End If
            fuzzyLast = True
            'Reset search name
        End If
        FileOpen 1, "Employee"
        'Loop through file
            FileGet 1, inEmp
            If fuzzyFirst And fuzzyLast Then
                found = (InStr(inEmp.Fname, searchFname) > 0 And InStr(inEmp.Lname, searchLname) > 0)
            ElseIf Not fuzzyFirst And Not fuzzyLast Then
                found = (inEmp.Fname = searchFname And inEmp.Lname = searchLname)
            Else
                'search first name
                If fuzzyFirst Then
                Else
                    found = inEmp.Fname = searchFname
                End If
                'Check last name
                If fuzzyLast Then
                Else
                    found = inEmp.Lname = searchLname
                End If
            End If
        Loop
        FileClose (1)
        If found Then
        Else
            MsgBox ("There are no employees with that name")
        End If
    End Sub
    The changes starting from the top:
    The type isn't a procedural declaration, but the rest can be, so move them all into the procedure unless it is needed elsewhere in your program.
    When it checks that the two text boxes aren't empty, throw an exit sub/function in there and kill the if statement. Some people disagree with this because of error handling and the such, so send it to a label if that's their gripe.
    Open the file right before it's being used and if it were my program rather than a homework assignment, I'd make inEmp an array and populate the array using a function that open, reads the whole file into the array and then closes it again. That way any other programs using the file wont be walking on each other.
    The first if in the loop handles the times when both the fuzzy searches are on. A Boolean can be set both using
    Code (Text):
    If 2+2=4 Then Boolean=True Else Boolean = False
    or
    Code (Text):
    Boolean = 2+2=4
    both of which result in True. (Hope that makes sense, ask if it doesn't.) So, in this one line I'm essentially doing
    Code (Text):
    End If
    The same is true for the second If statement handling the times when neither Fuzzy's are true.
    And lastly, the Else statement, the red head step child of the If/Then statement. :-) This is handling the fuzzys when 1 or the other is true.
    After the loop I'm closing the file.
    I hope I was able to help you with your assignment, feel free to question my changes, it is early in the morning here.
  4. Dec 1, 2008 #3
    Thank you very much. Everything that I had to do, you did. Thanks Again. :D
  5. Dec 1, 2008 #4
    If that's the case can I get partial credit for the assignment? :biggrin:
    Do you at least understand what I had done?
  6. Dec 1, 2008 #5
    haha sure you can get partial credit!
    Yes, I do understand what you did. Thanks again. You really clarified certain things I didn't understand.
