How to Find the Tangent Vector to a Path under Vec Calc Transformation?
In summary, the problem is to find the tangent vector to the image of the path c(t) under the vector-valued function f at t=0. Using the chain rule, the tangent vector is found to be (2, 0).
tandoorichicken
245
The Problem: No clue how to begin the following. The textbook isn't too clear.
Let [itex]f: \mathbb{R}^2 \rightarrow \mathbb{R}^2 ; (x,y) \rightarrow (e^{x+y}, e^{x-y})[/itex] Let c(t) be a path with c(0)=(0,0) and c'(0)=(1,1). What is the tangent vector to the image of c(t) under f at t=0?
Any help at all would be much appreciated.
Let [tex] \vec{c}(t) = \left< x(t), y(t)\right> [/tex]
then the image of c(t) under f is
[tex] f( \vec{c}(t) ) = f(x(t), y(t)) = \left( e^{x(t)+y(t)},e^{x(t)-y(t)}\right)[/tex]
The tangent vector is
[tex] \frac{d}{dt} f( \vec{c}(t) ) =\frac{d}{dt} f(x(t), y(t)) = \frac{d}{dt}\left( e^{x(t)+y(t)},e^{x(t)-y(t)}\right) = \left( \frac{d}{dt} e^{x(t)+y(t)}, \frac{d}{dt} e^{x(t)-y(t)}\right) [/tex]
[tex]= \left( e^{x(t)+y(t)}\left( x^{\prime}(t)+y^{\prime}(t)\right) , e^{x(t)-y(t)}\left( x^{\prime}(t)-y^{\prime}(t)\right) \right)[/tex]
evalute at t=0 to get
[tex]\left( e^{x(0)+y(0)}\left( x^{\prime}(0)+y^{\prime}(0)\right) , e^{x(0)-y(0)}\left( x^{\prime}(0)-y^{\prime}(0)\right) \right)[/tex]
recall that c(0)=(0,0) and c'(0)=(1,1) and hence x(0)=0, y(0)=0, x'(0)=1, and y'(0)=1 so that
[tex]\left( e^{x(0)+y(0)}\left( x^{\prime}(0)+y^{\prime}(0)\right) , e^{x(0)-y(0)}\left( x^{\prime}(0)-y^{\prime}(0)\right) \right) = \left( e^{0+0}\left( 1+1\right) , e^{0-0}\left( 1-1\right) \right) = \left( 2 , 0\right)[/tex]
is the tangent vector to the image of c(t) under f at t=0.
Though I'm not sure... is f a vector valued function of vectors?
Yes, that's exactly what [itex]f: \mathbb{R}^2 \rightarrow \mathbb{R}^2 ; (x,y) \rightarrow (e^{x+y}, e^{x-y})[/itex] means.
And your solution is completely correct. It's really an exercise in using the chain rule.
Thanx Ivy.
1. What is Vec Calc - tangent to path?
Vec Calc - tangent to path is a mathematical concept that involves finding the direction of the tangent to a curve at a given point. It is used in vector calculus to calculate the slope or rate of change of a path at any point.
2. How is Vec Calc - tangent to path used in real-life applications?
Vec Calc - tangent to path is used in various fields such as physics, engineering, and computer graphics to determine the direction and velocity of an object's motion along a curved path. It is also used in calculating rates of change in financial and economic models.
3. What are the key principles of Vec Calc - tangent to path?
The key principles of Vec Calc - tangent to path involve understanding the concept of a vector, which represents both magnitude and direction, and using derivatives to calculate the slope of a curve at a given point. It also involves understanding the concept of a tangent line, which is a line that touches a curve at only one point.
4. What is the difference between a tangent and a secant?
A tangent is a line that touches a curve at only one point, whereas a secant is a line that intersects a curve at two or more points. In Vec Calc - tangent to path, we are primarily concerned with finding the direction of the tangent to a curve at a single point.
5. Are there any common mistakes to avoid when using Vec Calc - tangent to path?
Some common mistakes to avoid when using Vec Calc - tangent to path include forgetting to find the derivative of the curve, using the wrong point on the curve, and not considering the direction of the tangent. It is important to carefully follow the steps and pay attention to the given information to avoid these mistakes.
