Vector Addition displacement
In summary, the roller coaster travels 200 ft horizontally and then rises 135 ft at an angle of 30* above the horizontal, followed by traveling 135 ft at an angle of 40* downward. Its displacement from its starting point is 420 ft. To find the displacement in degrees, the x and y components must be calculated using trigonometry. The vertical component is found to be 154 ft, resulting in a displacement of -3* (or 357*) below the horizontal.
twotaileddemon
260
A roller coaster moves 200 ft horizontally and then rises 135 ft at an angle of 30* above the horizontal. It then travels 135 ft at an angel of 40* downward. What is its displacement from its starting point?
Standard trig, I guess.
I know that the displacement in feet is 420 ft, and I did that using trig which I could type up, but I already am 100% positive of that answer. But I need to find it in degrees too. For instance, 10* below the starting point, or 350*. But I just don't know how to get it! I drew a huge diagram on scrap paper with A - B, B - C, C - D, and A - D following the above information. Any tips or guidance would be greatly appriciated.
Edit: I'll explain my work better. At a 30* angle, the rollercoster traveled 135 feet. Thus, the distance from the start traveled horizontally is 135cos30 =116.91 ft. Furthermore, it traveled down at a 40* angle, which is 50* in respect to the ground, so 135sin50=103.4 ft. 200 ft + 117 ft + 103 ft = 420 ft, which is the answer I got and what the "webassign" (computer program I use in class for homework) got (it tells you if the answer is right). Now I need to figure out how many degrees below the horizontal (starting point) the rollercoster ended up. Any help from this point is appreciated greatly ^^
420 ft (rounded to the nearest foot) is the horizontal component of the displacement. What is the vertical component?
When you have both the horizontal and vertical components, you should be able to compute the magnitude and direction (in degrees above or below the horizontal axis, depending on whether the vertical component of displacement turns out positive or negative) of the displacement.
(I assumed that "rises 135 ft at an angle of 30*" means it travels a distance of 135 ft, not that it's change in height is 135 ft. It's not clear that this is the right interpretation.)
Ah.. so the vertical component is what I'm missing. That would certainly make things much easier. Is the vertical component how much the roller coster travels from the end of the 200 feet to the end of its decline?
You're right though, it travels 135 feet but does not gain 135 feet in height above the ground. It goes up at a 30* angle and moves a total of 135 feet
well the total displacement rounded to 2 significant figures is 420 o.o
But yea get the x/y components of the 3 vectors added up and you'll get the angle that it makes.
In order to get the components of vectors you do this:
if you have vector z with equation z=r+theta.
R is the maginute and theta is the angle which can be + or - depending on the question. Your problem says 40* but 40* up? no down so it's actually -40* for that vector.
x-component of z = rcos(theta)
y-component of z = rsin(theta)
add up your 3 vector's 2 components each.
total vector say...S
x component of S = x components of other vectors added together.
y compoment of S = y components of other vectors added together.
[tex]r=\sqrt{S_x^2+S_y^2}[/tex]
and:
[tex]\tan\theta = \frac{S_y}{S_x}[/tex]Edit: ok yea you got the x components now do the same for the y components. Since you know tan (theta) = the sum of components y/x so then theta = ?
So for the y
135sin30 = 67.5
135cos50 = 86.78
So I get together 154 (rounded) for the y component
and thetha would equal around 20*
So I would end up getting 20*... below the horizontal? In other words, 340* counterclockwise?
Or would it be above? On fruther notice, I saw no negatives in my calculator, so it is 20* above the horizontal?
hm..ok wait you did a few things wrong but still got the right answer xD
in your x components all are r *cos (theta)
40* down is -40* with respect to the x-axis
so it should be 135cos(-40) instead of 135sin(50) but the answer is the exact same thing (420)
when you solve for the y components:
the first one's right but for the second one use sin and -40* which it should be and post what you get (I got some smalll angle)
135sin(-40) = -86.776
then adding that to 67.5 you get -19.2763
the degree would be -2.627, which I would round to 3
So the answer is 3* below the horizontal or 357* counterclockwise?
yea -3* (357*) or maybe -2.63* (357.37*) depending on how many significant figure's the website asks for.
edit: no problem glad I could help you out
Thank you very much! I can honestly say I understand what I did wrong and this will greatly help me! I'm glad I didn't give up on the problem. Thanks so much again! ^_^
1. What is vector addition displacement?
Vector addition displacement is a mathematical operation used to calculate the total displacement of an object when it undergoes multiple displacements in different directions. It takes into account both the magnitude and direction of each displacement to determine the overall displacement.
2. How is vector addition displacement calculated?
Vector addition displacement is calculated by breaking each displacement into its horizontal and vertical components, adding the components separately, and then combining the horizontal and vertical components to find the resultant displacement. This can be done using trigonometric functions and the Pythagorean theorem.
3. What is the difference between vector addition displacement and scalar addition displacement?
The main difference between vector addition displacement and scalar addition displacement is that vector addition displacement takes into account the direction of each displacement, while scalar addition displacement only considers the magnitudes of the displacements. This means that vector addition displacement can result in a different value than scalar addition displacement.
4. Can vector addition displacement be negative?
Yes, vector addition displacement can be negative. This can occur when displacements in opposite directions cancel each other out, resulting in a net displacement of zero. In this case, the negative sign indicates the opposite direction of the displacement.
5. What are some real-world applications of vector addition displacement?
Vector addition displacement is used in various fields such as physics, engineering, and navigation. It can be applied to calculate the displacement of objects in projectile motion, the displacement of forces acting on a structure, and the displacement of a moving object in relation to a fixed point. It is also used in GPS navigation to determine the total displacement of a vehicle from its starting point.
