Vector addition help
I got a problem on a homework but the wording is kind of confusing and i dont know how to place it down on paper in a way that i can solve it...thanks for all the help..it looks basic, I find the Problem in weather its B+C=7i+5j or B+C=C being b+(7i+5j)=C
1: A vector, B, when added to the vector C=7i+5j yields a resultant vector which is in the positive y direction and has a magnitude equal to that of C. what is the magnitude of B?
Answers and Replies
You know for sure that B = -7i + yj, how do you suppose you find what y should be? What is the magnitude of C? Do the two vectors look similar at all?
So magnitude of (B + C) = sqrt(7^2+5^2)
and the y component in A when added to C's y component has to be greater than 0.
im gettin 7.9 on the value of B..is that correct?
thanks for your help
Oh, which vector is supposed to have the same magnitude as C? If vector B is supposed to have the same magnitude then it should be B = -5i + (what)j, but if the resultant vector, call it D, is supposed to have the same magnitude then you need B = -5i + (you find it)j. Your answer would not be right for either case.
Related Threads on Vector addition help
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
