Vector calculus question
  1. Oct 17, 2014 #1
    Problem: Consider a system for which Newton's second law is $$ \frac {d \vec v}{dt} = - [ \frac {h(r)h'(r)}{r} + \frac {k}{r^3} ] \vec r- \frac {h'(r)}{r} \vec L $$ where k is a constant, h(r) is some function of r, h'(r) is its derivative and L = r x v is the angular momentum. Show that $$ \frac {d \vec L}{dt} = - \frac {h'(r)}{r} \vec r × \vec L$$ and use this equation to prove that L is not generally conserved, but its magnitude L is conserved.
    Attempt: I've done the first part of the question, but I don't know how I should go about showing that L is not conserved but its magnitude is conserved. Any hints would be appreciated.
  3. Oct 17, 2014 #2
    Dick
    The magnitude squared is given by the dot product of L with itself. Can you show the time derivative of that is 0?
  4. Oct 17, 2014 #3
    So |L|^2 = (r×v)⋅(r×v) = (rr)(vv) - (vr)(vr) = |r|^2 |v|^2 right? But how would I show the time derivative of this to be 0? [itex] \frac {dL}{dt} = r \frac {dv}{dt} + v \frac {dr}{dt} [/itex], but how do I make this equal 0?
  5. Oct 17, 2014 #4
    Dick
    You want to show the time derivative of ##L \cdot L## is zero. Use the product rule and your given expression for dL/dt. Can you tell me why dL/dt must be perpendicular to L?
Have something to add?
Draft saved Draft deleted
Similar Discussions: Vector calculus question
  1. Vector calculus question (Replies: 30)
Loading...
