1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Vector calculus -.-
  1. Nov 19, 2013 #1
    Prove that ##∇ × (\frac{\vec{a} × \vec{r}}{r^n})= \frac{2-n}{r^n}\vec{a}+\frac{n(\vec{a}.\vec{r}) \vec{r}}{r^{n+2}}##
    Nothing is mentioned about ##\vec{a}## so I'm assuming it is a constant vector. Also ##\vec{r} = <x, y, z> ## and ##|r|=r##
    2. Relevant equations
    3. The attempt at a solution
    What I don't get is why am I not allowed to do the following:
    ##L.H.S = \frac{1}{r^n} (∇ × (\vec{a} × \vec{r}) ) ##
    ## = \frac{1}{r^n} ((∇.\vec{r})\vec{a} - (∇.\vec{a})\vec{r} )## ---(using vector triple product formula)
    And since ##∇.\vec{a} = 0## since ##\vec{a}## is a constant and also ##∇.\vec{r}=3##
    ##L.H.S = \frac{3\vec{a}}{r^n} ##
    But then a black hole gets generated somewhere in the universe because the identity cannot be proved from here.
  3. Nov 19, 2013 #2
    I get it... r is not a constant. damn me
  4. Nov 19, 2013 #3
    If you don't mind, can you please post the solution you have found? Thanks!
  5. Nov 19, 2013 #4
    Easy way:
    Using that for scalar valued point function ∅ and a vector valued point function ##\vec{f}##,
    ##∇× (∅\vec{f}) = ∇∅ × \vec{f} + ∅ (∇ × \vec{f})##
    L.H.S. ## = ∇(\frac{1}{r^n}) × \vec{f} + ∅ (∇ × \vec{f}) ##
    ## = (-nr^{-n-2}\vec{r} ) × (\vec{a} × \vec{r}) + \frac{1}{r^n} (∇ × (\vec{a} × \vec{r}) )##
    ## = -nr^{-n-2} (\vec{r} × (\vec{a} × \vec{r})) + r^{-n} (2\vec{a}) ##
    ## = -nr^{-n-2} [(\vec{r} . \vec{r})\vec{a}-(\vec{r}.\vec{a})\vec{r}] + r^{-n} (2\vec{a}) ##
    ## = -nr^{-n-2} r^2\vec{a} + nr^{-n-2}(\vec{r} . \vec{a})\vec{r} + 2r^{-n}\vec{a} ##
    phew..simplifying further will yield the RHS.
    Note that I've used the following:
    ## ∇r^n=nr^{n-2} \vec{r}##
    ##∇ × (\vec{a} × \vec{r}) = 2\vec{a} ##
    Hard way:
    You can do it by finding the actual cross product on the LHS like I did, keeping in mind that r is not a constant scalar xD
    Also, later on you have to make an adjustment by adding and subtracting ## \frac{n}{r^{n+2}} a_{1,2,3} x^2 ## in each component of the cross product.
  6. Nov 19, 2013 #5
    From my book
    I've made many corrections to my last post
  7. Nov 19, 2013 #6
    Thanks a lot MrWarlock! :)
    The alternative method is much better.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Vector calculus -.-
  1. Vector Calculus (Replies: 1)
  2. Calculus on vectors (Replies: 14)
  3. Vector calculus (Replies: 12)
  4. Vector calculus (Replies: 6)
  5. Vector Calculus (Replies: 1)
Loading...
