Vector difference help
hi i am having problems with this problem
Vector A has a magnitude of 8.00 units and makes an angle of 45.0 degrees with the positive x-axis. Vector B also has a magnitude of 8.00 units and is directed along the negative x-axis. Using graphical methods, find (a) the vector sum A+B and (b) the vector difference A-B.
2. Relevant equations
A+B
A-B
3. The attempt at a solution
Do i just use the graph to count?
What about the difference vector?
1,002
64
Re: Vectors
What is the graphical method of adding two vectors? Subtracting one vector from the other is defined as simply adding the negative of the second vector to the first. Using a parallelogram made up of the vectors, you can see both of these operations.
Re: Vectors
thank you
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
