Vector Field: Showing Divergence & Curl A = 0
In summary, a vector field is a mathematical concept that assigns a vector to every point in a given space. A vector field with a divergence of 0 means that the net flow of the vector field is balanced at every point. The divergence of a vector field can be calculated by taking the dot product of the vector field with the del operator and then taking the gradient of that dot product. A vector field with a curl of 0 means that the field is irrotational, and the curl can be calculated by taking the cross product of the vector field with the del operator and then taking the gradient of that cross product.
danai_pa
29
A vector field is difined by A = f(r)r.
a) show that f(r) = constant/r^3 if divergence A equal to zero.
b) show that curl A is alway equal to zero
Do you know the equations for divergence and curl in spherical coordinates?
yes i known.
so plug it in...
StatusX said:
so plug it in...
i think you mean, find a divergence and curl in a spherical coordinates. vector r is represent r, theta and phe
1. What is a vector field?
A vector field is a mathematical concept that assigns a vector to every point in a given space. This can be represented visually as arrows or lines, with the direction and magnitude of the vector indicating the direction and strength of a particular physical quantity at that point.
2. What does it mean for a vector field to have a divergence of 0?
A vector field with a divergence of 0 means that the net flow of the vector field, or the amount of vector flux, is zero at every point. This can also be interpreted as the vector field having no sources or sinks, as the flow in and out of a given region must balance out.
3. How is divergence of a vector field calculated?
The divergence of a vector field can be calculated by taking the dot product of the vector field with the del operator (∇) and then taking the gradient of that dot product. In other words, it is the sum of the partial derivatives of each component of the vector field with respect to each coordinate.
4. What is the significance of a vector field having a curl of 0?
A vector field with a curl of 0 means that the field is irrotational, or has no rotation. This can also be interpreted as the vector field having no circulation, as the vector field lines do not form closed loops. In physics, this can represent a conservative force field, where the work done by the force is independent of the path taken.
5. How is the curl of a vector field calculated?
The curl of a vector field can be calculated by taking the cross product of the vector field with the del operator (∇) and then taking the gradient of that cross product. In other words, it is the difference between the partial derivatives of each component of the vector field with respect to each coordinate.
