Vector help please
  • Thread starter songoku
166
Three units vectors a, b, and c have property that the angle between any two is a fixed angle [tex]\theta[/tex]
(i) find in terms of [tex]\theta[/tex] the length of the vector v = a + b + c
(ii) find the largest possible value of [tex]\theta[/tex]
(iii) find the cosine of the angle [tex]\beta[/tex] between a and v
unit vector = vector with length 1unit
magnitude of vector = [tex]\sqrt{x^2+y^2+z^2}[/tex]
[tex]\cos \theta = \frac{r_1\cdot r_2}{|r_1||r_2|}[/tex]
(i) I think I get it right. The answer is [tex]\sqrt{3+6\cos \theta}[/tex]
(ii) I don't know how to do this. I think [tex]\theta < 90^o[/tex] , but I can't find the exact value
(iii)
[tex]\cos \beta = \frac{a\cdot v}{|a||v|}[/tex]
After some calculation,
[tex]\cos \beta = \frac{2+\cos \theta}{\sqrt{3+6\cos \theta}}[/tex]
Can it be simplified further?
Thanks a lot
Answers and Replies
lanedance
3,304
i) looks ok
ii) think about the case when they are all in the same plane...
iii) shouldn't this be 1 + 2cos(theta) on the numerator?
Office_Shredder
Staff Emeritus
646
Look at (i), and ask yourself for what values of theta can that length even exist? You know that v=a+b+c must be an actual vector, which means it must have an actual length
lanedance
3,304
though v can be the zero vector, with zero length
166
Hi lanedance and Office_Shredder
Ah yes or (iii) it should be 1 + 2cos(theta). I found it but dunno why I wrote 2 + cos(theta) here....:redface:
For (ii) , The length of v can exist if :
[tex]3+6 \cos \theta \geq 0[/tex]
I found the value for [tex]\theta[/tex] = [0o, 120o] U [240o, 360o] for [tex]0^o\leq \theta \leq 360^o[/tex]
How to continue :confused:
Thanks
lanedance
3,304
so you're pretty much there,
first though, the way to visualise this is to consider all the vectors pointing in the same direction, theta = 0. this is where |v| = 3
as the angle is increased, imagine the vectors spreading something like a flower opening, keeping the same angle between each, with |v| decreasing. The maximum angle occurs when they are all in a plane, theta = 120, and |v| = 0. Agreeing with the first range of your solution.
I also think you only need to consider upto 120 (solutions for 120<theta<= 180 do not exist, and above 180 you can just measure the angle the other way)
166
Hi lanedance
Ahh I get it now
Thanks a lot for you both !!:smile:
Related Threads on Vector help please
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
