Vector Problem
  • Thread starter mikee
mikee
30
Prove that Vector A is perpendicular to Vector B if |VectorA + VectorB| = |VectorA-VectorB| and use this to prove that the angle formed by joining any point on a circle to the end points of a diameter is 90 degrees,
I really have no idea where to begin, i no that VectorA (dot) VectorB=0 for them to be perpendicular but i still don't really understand the second part of the problem, if somebody could point me in the right direction that would be appreciated thank you
Answers and Replies
Dick
26,263
621
(A+B).(A+B)=A.A+2A.B+B.B. What's (A-B).(A-B)? How can they be equal? For the circle problem take A to be the vector connecting the center of the circle to your point and B to be the vector connecting the center to one of the endpoints of the diameter. Do you see it now?
mikee
30
For the first part i meant that if |A+B|=|A-B| then A and B are perpendicular and i forgot to note it is in 3 space A(Ai,Aj,Ak), and i see what your saying for the second part but as i am picturing it the angle will be any angle depending on the vectors? Like if the vectors are perpendicular of coarse the angle will be 90degrees but the way i am understanding the question is that no matter what the angle will be 90 degrees
Dick
26,263
621
It doesn't depend on how many dimensions the space has it's still true. If |A+B|=|A-B| then A.B=0. Use the vectors. |A+B|^2=(A+B).(A+B). |A-B|^2=(A-B).(A-B). Again for the circle problem A+B and A-B are both points on the circle.
mikee
30
oo ok i see now, the only way for part one of the question to hold true is if the vectors are perpendicular and by using these vectors the second part of the question would hold true, i just assumed that the second part of the question held true for any two vectors, thanks for the help
Suggested for: Vector Problem
  • Last Post
  • Last Post
  • Last Post
