Homework Help: Vector Products & Properties
  1. Jan 16, 2009 #1
    x^2
    Which of the following are true?
    A) A vect. prod. C=C vect. prod. A
    B) The x-component of a vector can be +, -, or zero
    C) If A=BxC and C=64i, then Ax=0
    D) If A perp to B, then B dot A =0
    E) The magnitude of a vector is sometimes negative.
    F) The scalar (or dot) product of two vectors can be +, -, or zero.
    2. Relevant equations
    BxC = BC*cos(theta) where theta = angle between vectors
    3. The attempt at a solution
    Below are my attempts at proving or disproving each statements.
    A) False: Using the right hand rule, the direction of the resulting product will be inverted when comparing AxC and CxA
    B) True: A vector could cover horizontal distance to the right (positive), to the left (negative), or be a vertical vector with an x component of zero.
    C) False: 64i could potentially result in an answer where Ax = 64i
    D) True: BxA = BAcos(90) = BA*0 = 0
    E) False: A magnitude is the absolute value of a vector and therefore can never be negative.
    F) False: A scalar product must always be positive as all scalars are positive--they would be the absolute value of a vector.
    I tried answering B & D as true and the rest false but this was not correct. I am not sure which statements I am confused on. I'm fairly confident of my answers to A, B, D, and E while a little less sure on C and F.
    Thanks,
    x^2
  3. Jan 16, 2009 #2
    rl.bhat
    C)Since A=BXC. A is perpendicular to B and C. Since C = 64i is along x axis, Ax is zero.
    F) A.B = ABcos(theta). ANd cos(theta) can be +, - or zero.
  4. Jan 16, 2009 #3
    To emphasize more about F)
    define 2 vectors A = (-1, 1) and B = (1, -1)
    [tex] A \cdot B = -1 - 1 = -2 [/tex]
    Certainly negative.
  5. Jan 16, 2009 #4
    x^2
    Thanks for the replies! C definitely makes sense when using the right hand rule. For some reason I was still relating Ci to Ax without thinking that they were perpendicular. As for F I see what they are asking for--I guess I was thinking that scalar had to mean magnitude but in actuality they just meant dot product.
    Thanks for the help,
    x^2
