What is the magnitude of the resultant force and angle in this vector problem?
  • Thread starter recoil33
  • Tags
    Vector
In summary, the problem discussed was finding the magnitude of the resultant force and the angle it makes with the larger of two given forces. The Parallelogram Law was used to calculate the resultant force, but the wrong angle was initially used. The correct angle was found using the Law of Sines, and the final answers were 40.0N for the magnitude and 45.9 degrees for the angle.
recoil33
28
Okay, I don't really understand vectors exactly - I think i do, but then i confuse myself.
"Two forces have magnitudes of 26 N and 19 N and the angle between them is 125°. Find the magnitude of the resultant and the angle it makes with the larger of the two forces. Give answers correct to 1 decimal place."
Q1. Resultant Force(N):
Q2. Angle(theta):
Alright, i used the "Parallelogram Law"
Then ended up solving for:
|R2| = 262 + 192 - 2*(26)*(19)*Cos(125)
|R| = (262 + 192 - 2*(26)*(19)*Cos(125))(1/2)
|R| = 40.046
|R| = 40.0N
Although, my answer is wrong. Apparently I've used the wrong angle, something to do with a angle complementary with 180 degrees?
Any help will be appreciated.
(Can't solve Q2 without the answer to Q1) - I should be alright there.
recoil33 said:
Okay, I don't really understand vectors exactly - I think i do, but then i confuse myself...
Your problem is more with trig than vectors. Did you sketch the situation? In the Law of Cosines, angle C has to be opposite the longest side (the diagonal that cuts the 125º in this case).
Use the sketch to see what angle is opposite the diagonal and swap it for 125º in your calculation.
Hmm, I just gave this a shot myself and got the same magnitude for the r vector, it looks correct to me...!
What did you get for the angle?
I get something different.
Converting the forces to vectors and then adding them, we can attempt verify the result. Let...
A = Origin
B = 19N 'point' along the x-axis
C = 26N 'point' in the 2nd quadrant 125deg from the x-axis.
D = Resultant 'point'
We can find their coordinates by using unit-circle equivalencies:
AB = <19cos 0, 19sin 0> = <19,0>
AC = <26cos 125, 26sin 125> ~= <-14.913,21.298>
AB + AC = AD ~= <4.087,21.298> |AD| ~= 21.6866
Angle between AD and the x-axis is arctan 21.298/4.087 = 79.1372deg
So, the final answer = 21.7 N at an angle of 79.1deg from the smaller force-vector.
Is 125deg the proper angle to put into the parallelogram law? I think that is where your approach is not correct. 'Tip to tail' graphing will help find the proper angle using the parallelogram law.
Thanks everyone,
I realized i was using the wrong angle, i think i confused myself with putting the force of 26N 125 degrees away in the other direction. Which should not matter, although it confused myself.
Anyways, I solved it finally.
As for Q2.
I used the sin rule,
a/SinA = b/SinB
19/sin(theta) = |R|/Sin55
= (19Sin55)/21.687 = Sin(x)
= 45.9 Degrees
recoil33 said:
Thanks everyone,
As for Q2.
a/SinA = b/SinB
= 45.9 Degrees
Yep - I just used the x-axis/smaller force for my angle. You'll notice that:
125deg - your answer = my answer (and verifys the correctness)
1. What is a vector in mathematics?
A vector in mathematics is a quantity that has both magnitude (size) and direction. It is often represented by an arrow in a coordinate system.
2. How do you add vectors?
To add two vectors, you must first place them head-to-tail. Then, draw a vector from the tail of the first vector to the head of the second vector. The resulting vector, from the tail of the first vector to the head of the second vector, is the sum of the two vectors.
3. What is the difference between scalar and vector addition?
Scalar addition is adding two quantities that only have magnitude, such as numbers. Vector addition, on the other hand, involves adding two quantities with both magnitude and direction.
4. Can you add more than two vectors together?
Yes, you can add more than two vectors together. The same rule applies as with adding two vectors - place them head-to-tail and draw a vector from the tail of the first vector to the head of the last vector in the chain.
5. What is the commutative property of vector addition?
The commutative property of vector addition states that the order in which you add two vectors does not change the result. In other words, a + b = b + a. This property does not apply to all mathematical operations.
