Vector spaces
  • Thread starter daniel_i_l
daniel_i_l
a)A is an invertible 5x5 matrix with complex elements. Find all the values of det(A) where adj(adj(A)) = A. Use the definition of the adjoint (transpose of cofactor matrix)
b) u1,u2,u3 are linearly independent vectors in V. We define:
v1=u1+u2+u3, v2=u1-u2+u3, v3=-u1+3u3-u3
Does Sp{u1,u2,u3}=Sp{v1,v2.v3} ?
a) The definition of adj(A)
b) If A and B are subsets of space V then Sp(A) = SP(B) iff A is in Sp(B) and B is in Sp(A).
a) I tried to use the definition of the adjoint to find the adjoint of adj(A) but it quickly got so complicated that I couldn't see how to calculate det(A) from it. Is there a way to use the fact that A is a 5x5 matrix to simplify things?
b)I think that the answer is yes because obviously {v1,v2,v3} is in the span of {u1,u2,u3} because of their definition. And by solving the equation:
[v1|v2|v3][x]=[un] for all 0<n<=3 I can show that every u is a linear combination of v's and so {u1,u2,u3} is in Sp{v1,v2,v3}. Is that right?
Thanks.
Answers and Replies
matt grime
9,420
When you say you used the definition of adj(A), do you mearn you used the definition, or the formula? adj(A), is the (unique for det=/=0) matrix satisfying A*adj(A)= det(A)*Id.
daniel_i_l
I mean the formula: [tex] [adjA]_{ij} = (-1)^{i+j}*M_{ji} [/tex]
Where [tex] M_{ji} [/tex] is the minor (ji). (by minor (j,i) I mean the det of the matrix obtained by taking away the jth row and the ith coloum)
matt grime
9,420
yes, I know that what was you used. I didn't ask for my benefit.
HallsofIvy
41,847
966
Now, what relation does det(A) have to [tex] [adjA]_{ij} = (-1)^{i+j}*M_{ji} [/tex]?
As for B, you were told that u1, u2, and u3 are linearly independent. That means they are a basis for their span which must be of dimension 3. The real question is "Are v1, v2, and v3 linearly independent?"
Related Threads on Vector spaces
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
