Vector Spaces
  • Thread starter joemama69
Determine if the following sets are vector spaces
Part A) R^2; u+v = (u1 + v1, u2 + v2); cu = (cu1,cu2)
part b) M_2,2
A + B = |(a_11 + b_11) (a_12 + b_12)| & cA = |ca_11 ca_12|
|(a_21 + b_21) (a_22 + b_22)| |ca_21 ca_22|
sorry this is a little crude but those are both suppose to be 2X2 matricies
Part A) Yes, it is a vector space because it follows the addition & multiplication properties of vector spaces
Part B) yes it is a vector space because the set is closed under matrix addition & sclar multiplication
Are these statments true and a sufficient answer
Answers and Replies
If they both are closed under scalar multiplication and addition, then you can conclude that they might be a subset of a given vector space. To check whether or not they are vector spaces, you have to go through the 10 axioms. Does it sound familiar?
Your solution is not sufficient because you need to go through each and every vector space axiom to prove that it is in fact a vector space (and you need to show where only one axiom fails to prove it is not a vector space).
It is easy to see that pointwise addition is a simple procedure, but I think the point of the exercise is to go through the seven vector space axioms - many are trivial but as far as it stands now your answer is not sufficient.
Related Threads on Vector Spaces
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
