Homework Help: Vector Trouble
  1. Dec 3, 2006 #1
    Given a plane S: x+y+z=8 and two points A(6,5,3) and B(10,5,-1), find the point P on plane S such that a line from point A bounces off of the plane S at point P and passes through point B.
    2. Relevant equations
    3. The attempt at a solution
    If I know that the angle of incidence = the angle of reflectance, then I can also say that a normal vector from plane S bisects will these two points at point P. So if I can proove that the angle between vectors AP and n is the same as the angle between vectors BP and n then this should solve my problem. Well, this is what I tried to show at least, and did not come up with the angle between the two vectors to be the same.
    I found my normal vector n to be <1,1,1> and I took my point P to be (8,0,0). So, from there, I found vectors AP and BP to be <2,-5,-3> and <-2,-5,1> respectively.
    Any help on which direction to go towards next would be a great help! Thank you!!
  3. Dec 3, 2006 #2
    Points A and B are in fact the same distance from plane S. (Can you show this?)
    Draw a diagram reflecting this, and add point P to the diagram. What do you realize?
  4. Dec 3, 2006 #3
    I worked out the distances to be different than eachother. To find the distance of points A and B from plane S, i first found a point on plane S to reference from, call it Q. So, to find the distance of point A from plane S, i found:
    h1 = |QA - proj (QA on n)|, where n is the normal vector for plane S.
    I came up with a value of ~32.4.
    to find the distance of point B from plane S, i found:
    h2 = |QB - proj (QB on n)|, where again, n is the normal vector for plane S.
    I came up with a value of ~134.28.
    What happened? If I don't have the same height, how can I relate the two angles to eachother?
  5. Dec 3, 2006 #4
    Shouldn't it be [tex]h_{1} =\ \mid proj\ (\ QA\ on\ n\ ) \mid[/tex]?
    Try drawing a diagram, it should help.
