Homework Help: Vectors and magnetic force
  1. Oct 23, 2004 #1
    magnetic forces on a conductor
    A straight, vertical wire carries a current of 1.13A downward in a region between the poles of a large superconducting electromagnet, where the magnetic field has a magnitude of 0.553T and is horizontal.
    What is the magnitude of the magnetic force on a section of the wire with a length of 1.00cmthat is in this uniform magnetic field, if the magnetic field direction is 29.0degrees south of west?
    i read the textbook and tried using F= current*length*magnetic field*sin(theta) and i got .00303 N.. is this correct or am i going about this all wrong?
  3. Oct 24, 2004 #2
    Doc Al
    Staff: Mentor
    In that formula, theta is the angle between the current in the wire and the magnetic field. In this problem the wire is vertical (call it along the z-axis) and the magnetic field is horizontal (somewhere in the x-y plane). So what is the angle between them?
  4. Oct 24, 2004 #3
    i just tried taking the cross product of I and B but that didnt work out right? how wold i find the angle between the magnetic field and the current?
  5. Oct 24, 2004 #4
    Doc Al
    Staff: Mentor
    The cross product would work fine if you used the correct angle between the vectors. Hint: the wire is vertical and the field is horizontal. :smile:
  6. Oct 24, 2004 #5
    would that angle just be the one given then?
  7. Oct 24, 2004 #6
    Doc Al
    Staff: Mentor
    angle between vertical and horizontal = ?
    If by that you mean "29.0 degrees", then no. That's the angle the field makes with west, not the angle it makes with the wire.
    The way I'm picturing this coordinate system is: the wire is along the z-axis, north is along the y-axis, and east is along the x-axis. Specifying the angle that the field makes with west (the -x axis) doesn't change the fact that the field is horizontal and thus perpendicular to the wire.
  8. Oct 24, 2004 #7
    help please!
  9. Oct 24, 2004 #8
    Anyone help this homework problem
  10. Oct 25, 2004 #9
    Doc Al
    Staff: Mentor
    Did you read my response? Do you know what perpendicular means?
  11. Oct 25, 2004 #10
    so that angle is 90 degrees? if so, what does the 29 have to do with anything?
  12. Oct 25, 2004 #11
    Doc Al
    Staff: Mentor
    Yes.
    You'd need that to find the direction of the magnetic force.
  13. Oct 25, 2004 #12
    i guess now i'm trying to find the angle the magnetic force will make relative to some axis, say north. time to use the right hand rule correct?
  14. Oct 25, 2004 #13
    Doc Al
    Staff: Mentor
    Yes, use the right hand rule.
  15. Oct 25, 2004 #14
    in determining the direction and the angle the magnetic force on teh wire makes with the y-axis (north), i should be applying the right hand rule to the vectors of the current and magnetic field correct?
  16. Oct 26, 2004 #15
    Doc Al
    Staff: Mentor
    That is correct.
