Vectors and Planes
speedycaster
Question 1.
Given position vectors OA : i+2j-k and OB: 2i+j+3k in a 3D Cartesian space with origin O of the points A and B.
a) Find the scalar equation of the plane which contains A and which is perpendicular to vector AB.
b) Find the shortest distance from the point (1,-1,1) to the plane obtained in a (a)
Here is what i did
(a) Equation of line AB
r= (2,1,3)+ t(1,-1,4)
AP.n = 0
OP.n = OA.n
(x,y,z).(1,-1,4) = (2,1,3).(1,-1,4)
x-y+4z = 13 [equation of plane]?
(b) vector form of plane => r.(1,-1,4) = 13
line equation => r= (1,-1,1) + t(1,-1,4)
Using r=r for both equations i get t= 2/9
Substitute t=2/9 into line equation giving me (11/9, -2/9, 17/9)
I'm stuck here then for part (b)
I'm pretty weak in this chapter, couldn't seem to grab the concept here.
Question 2.
Obtain the scalar equation of the plane which passes through point P(1,2,3) and contain a straight line
x(t)= 3t
y(t)= 1+t
z(t)= 2-t
t is the parameter of the line
Equation of the line= (0,1,2) + t(3,1,-1)
Let Q and R be the points on the line
t=0 Q=(0,1,2)
t=1 R= (3,2,1)
Therefore PQ= (-1,-1,-1) PR= (2,0,2)
PQxPR= (-2,0,-2)
Thus the equation of the plane
a(x-x1) + b(y-y1) + c(z-z1)= 0
-2(x-1) + 0 -2(z-3) = 0
-2x - 2z + 8 = 0
is this correct?
Answers and Replies
LCKurtz
Insights Author
774
Question 1.
Here is what i did
AP.n = 0
OP.n = OA.n
You will find that (1,2,-1) doesn't work in that equation so the point is not on the plane.
For R = <x,y,z>, the form on the equation of a plane is
[tex](\vec R - \vec A)\cdot \vec N = 0[/tex]
The correct equation for the plane might get you started.
speedycaster
so what does it mean when it says the plane contains A?
so is it like this?
[(x,y,z)-(1,2,-1)].(1,-4,4)=0
1(x-1)-4(y-2)+4(z+1)=0
x-4y+4z=11
LCKurtz
Insights Author
774
so is it like this?
x-4y+4z=11
Yes, except check the sign on the 11.
Suggested for: Vectors and Planes
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
