Vectors and projectiles
  1. Nov 29, 2011 #1
    A plane heads out to L.A with a velocity of 220m/s in a NE direction, relative to the ground, and encounters a wind blowing head-on at 45m/s, what is the resultant velocity of the plane, relative to the ground.
    2. Relevant equations
    Pythagorean Theorem ?
    Simple subtraction
    3. The attempt at a solution
    Here is an Image I made in paint to help visualize the solution of the problem... I believe I'm not solving this correctly.
    http://img443.imageshack.us/img443/9841/physics1.jpg [Broken]
    Uploaded with ImageShack.us
    I'm pretty much grabbing in the dark here since I cannot understand everything. Sorry for wasting your time in a way.
  3. Nov 29, 2011 #2
    cepheid
    Staff Emeritus
    NE is at a bearing of 45 degrees so that that "northerly" component of the plane's velocity is (220 m/s)cos(45 deg) and the "easterly" component is (220 m/s)sin(45 deg). Now, the westward wind doesn't affect the velocity along the N-S axis, but it does affect the velocity along the E-W axis. Taking east to be the positive direction and west to be the negative direction along the E-W axis, the new velocity along this axis is:
    (220 m/s)sin(45 deg) - 45 m/s = v_ew
    (where I've given it a name, to remove clutter).
    The resultant total velocity is easy to find. The N-S and E-W components still form a right triangle, so that the sum of their squares is equal to the square of the total velocity (in magnitude):
    (v_total)^2 = [(220 m/s)cos(45)]^2 + (v_ew)^2
    EDIT: you can also get the angle of the resultant from this same triangle.
  4. Nov 29, 2011 #3
    Doesn't the problem say a head on wind? where are you getting westerly?
  5. Nov 29, 2011 #4
    cepheid
    Staff Emeritus
    Good call, I got it from the OP's diagram, but I see now that the OP was just wrong.
    To the OP: if the two vectors lie along the same line, you can add them by simply adding their magnitudes (or subtracting them if they are in opposite directions).
