Are Vectors Always Positive in a 1-Dimensional System?
  • Thread starter dE_logics
  • Tags
    Vectors
In summary, the conversation discusses the concept of vectors and their signs. It is clarified that vectors do not have a sign, and the minus sign attached to a vector only represents an operation of additive inverse. The conversation also mentions the conditions for a set of elements to be considered vectors, and the difference between scalars and vectors. Overall, the conversation highlights the fact that vectors do not have a sign and the use of the minus sign in relation to vectors.
dE_logics
742
I know they don't...there is no reason.
If they did have a sign, values would have been positive only on the first quadrant (2-d).
But suppose we have a vector B...if another vector is radically opposite in direction but same in magnitude, we call it -B, then what's this sign?
Mathematics news on Phys.org
I don't really see why not.
Let's use [tex]x = (x_1,x_2)[/tex]. If we want a vector that points in the opposite direction with the same magnitude we can just use scalar multiplication of vectors:
[tex](-x_1,-x_2) = (-1)(x_1,x_2) = -(x_1,x_2) = -x[/tex]
Then [tex]-x[/tex] is, in a sense, the negation of vector [tex]x[/tex] but only of [tex]x[/tex] and vectors equal to [tex]x[/tex].
What is the sign of the vector (1,-1)?
You do not assign a sign to it, instead if you say that B=(1,-1) then -B=-(1,-1)=(-1,1). If then A=(-1,1), then A=-B and B=-A. Minus isn't an object, it is an operation which mirrors the vector in its origin. Like, in reality we just have the numbers 0 to infinity, the negative numbers are just mirrored using the minus operator. But you can still say that A=-5, then -A=5, it is exactly the same thing as you are doing with vectors.
What do you mean by (a,b)...those are coordinates right?
Back to the original post.
-B is the additive inverse of the vector B. That minus sign does not "belong" to B, it is an operation applied to B. Compare to 1 versus -1. Like B and -B, 1 and -1 are additive inverses of each other. However, the minus sign attached to -1 is an integral part of the number "-1". Real numbers have a sign. Vectors don't.
Vectors are elements of a vector space,
and one of the conditions for a vector space is that anything may be multiplied by a scalar,
and "scalar" means any real number (ok, technically we can also have complex vector spaces, but don't bother with them) …
so for any vector B, there's a vector kB, for any real number k.
It isn't just k = ±1 …
k isn't a sign. :smile:
We write -B rather than -1*B because the existence of an additive inverse is also a condition for a space to be a vector space. The field of scalars might even not have an element called "-1". Think of a vector of Booleans.
Hi D H! :smile:
ah, but we're talking about a space with four quadrants, and I'm pretty sure the Booleans all live in a circular wormhole, where they survive by pure logic :wink:
dE_logics said:
… values would have been positive only on the first quadrant (2-d). …
That elements of a set can be multiplied by a scalar is one prerequisite for calling the elements of that set "vectors". However, we write the additive inverse of a vector B as -B rather than -1*B. Note that -2B is obviously shorthand for -2*B, and it looks perfectly natural to write -2B. We don't do that with -1*B. -1B looks incredibly clunky! We write -B instead, and this is not just shorthand for -1*B.
There is an even more basic prerequisite than multiplication by a scalar that must be satisfied in order to call the elements of that set "vectors": The set must form an abelian group with addition as the operator. The standard symbol for the inverse operator for addition is to prefix the element with a minus sign. In other words, -B.
One proves that, for vector spaces, "-1 times v" is the same as "the additive inverse of B", of course. They are not defined as the same thing.
As for the "sign" of an object, that normally implies sets of "positive" and "negative" objects which in turn implies an order. A vector space of dimension greater than 1 cannot be ordered.
So doing this is not right -
Suppose we have a vector B
Assume C = -B (this step should be wrong)
Then if B = 3
Then C = -3 :tongue2:
BTW that's only a scaler value, so it obviously doens't have any sign.
So -1 * B should not exist...since, obviously -1 is a scaler and should not have a sign.
?? :confused:
All numbers (positve zero or negative) are scalars.
Scalars, at least in the context of vector spaces, most certainly can have a sign. The scalars must be a field: Something with addition and multiplication, identity elements (for addition and multiplication (e.g., zero and one), and additive and multiplicative inverses.
? A "scalar" is a member of the field the vector space is defined over. In many applications, the field is the field of rational numbers or field of real numbers. And those certainly do have signs!
Is scaler a scalar used for scaling?
Ok.
But when we take suppose, motion in one dimension, the displacement/velocity/acceleration are vectors, yet they have a sign...most probably cause they are taken WRT another inverse vector.
But problem is we actually use those sign conventions in the numerical analysis...shouldn't that give the wrong answer?
Cause as I said before...doing this should be wrong -
Then if B = 3
Then C = -3
So vector C has a negative value.
:confused:
dE_logics said:
:confused:
Borek was being mean regarding your misspelling of scalar.
Hey, English is my second language, I have right to have doubts, don't I? :devil:
dE_logics said:
Ok.
No, that is 100% correct, vectors can have signs like that. A vector just have a length and a direction, however the sign tells us the direction.
In that way (-1,1) is not equal to (1,-1) since they point in opposite directions. Another way to describe the vector would be to say that they got a length sqrt2 and the first got an angle of 3pi/4 and the second got an angle of -pi/4. But saying both of those have equal meanings, and the signs are necessary since they tell you the direction.
That is 100% incorrect.The additive inverse operator is an operation that can applied to a vector. It is not an intrinsic part of the vector. Vectors have a magnitude and a direction. Those are intrinsic parts of the vector. Rather than repeating what HallsofIvy said, I'll simply quote him:
:rofl: :rofl: :rofl:
No doubt...best humour.
Klockan3 said:
No, that is 100% correct, vectors can have signs like that. A vector just has a length and a direction, however the sign tells us the direction.
:confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused:
What exactly is happening here?
Let me guess in this 1-d case, we assume one vector as a coordinate system and in 2-d or more, this assumed vector is gone...
I'm sorry but I'm sort of not getting it...
The angle for all vectors should be taken in either clockwise or anticlockwise direction a vector cannot have 2 angles considering one reference frame of either clockwise or anticlockwise.
Do we have a reference book? I'm downloading though...that 4.7 GB collection.
Actually I did not get what it means...'ordered'?...you mean sign convention?
A set is orderable means you can establish a total ordering on the set. In lay terms, you can put the set in some kind of ordered arrangement. The set {2 0 1 -1 -2} can be sorted via ≤ to form the ordered list {-2 -1 0 1 2}. There is no way to come up with a way to order vectors of dimension 2 or higher.
EDIT: oops. I posted this before I realized there was a second page to this thread ... I'll keep it here in case it's of any value.
This is the key point, isn't it? Asking whether a 2-d vector in a given quadrant is positive or negative is a meaningless question.
Yes, for a vector B we can define -B, but that doesn't mean one is positive and the other negative. B might point in the direction of anyone of the four quadrants, so you could have B=(-1,-1) and -B=(1,1), or B=(1,-1) and -B=(-1,1), which is even more ambiguous.
As for this:
Then if B = 3
Then C = -3
Saying B = 3 doesn't make a lot of sense if B is a vector. B must have a direction (unless it's a 1-d vector), so it must have as many components as there are dimensions in the space in which it lives - so you could say B = (3,0), or B = 3i. Otherwise, there's nothing wrong with the statements above.
Whoa ... what?
"in this 1-d case, we assume one vector as a coordinate system" -- a vector and a coordinate system are two different things. You can express a vector in terms of its coordinates in some chosen coordinate system.
"in 2-d or more, this assumed vector is gone" -- Given a Cartesian coordinate system, you can express vectors in terms of their Cartesian coordinates, which people have been implicitly doing here when they've written expressions like "B = (1,-1)", where 1 and -1 are the x- and y-components, respectively. You could also write B = i - j for the same vector, where i and j are unit vectors in the x and y directions.
You can also define a vector in terms of its length (magnitude) and direction, where the direction requires N-1 angles to be defined (N = number of dimensions). So, in 2-d you need length and one angle (typically anticlockwise from x-axis by convention), or in 3-d you need length and two angles, e.g. polar and azimuth angles, or latitude and longitude angles. Our vector above could then be defined as having length SQRT(2) and direction -45 degrees (using the convention I just mentioned).
Hi dE_logics! :smile:
?? :confused: looks like this is where you're misunderstanding vectors …
let's try to sort this out …
are you saying that you think a vector v is defined by a magnitude (|v|) and an angle?
that's certainly not the standard way of doing it: the standard way is to specify a basis (eg i j or -i -j), and to write it in the form v = xi + yj … or v = (-x)(-i) + (-y)(-j) :wink:
(and btw, angles in 2D are always anti-clockwise)
I kind of looks like tiny-tim and I are disagreeing, but I don't think we really are.
That's might be the way it's first taught, but I expect tiny-tim will agree that it's certainly possible to define vectors in terms of their magnitudes and directions, and there are plenty of situations where's that's a desirable way to do it. It's also taught fairly early-on in most intro. to vector courses, I believe.
Again, that's probably the most typical convention, especially when talking about a 2-d Cartesian space where we've labeled the axes by x and y. It's not universal, however - for example heading angles for velocity vectors are often given as degrees clockwise from North.
These are just little nitpicks, however - on the whole tiny-tim and I are saying the same things. I just wanted to clear up any potential confusion in case it looked like weren't.
Since in 2-d or 3-d the magnitude of a vector is different along different directions, since in 1-d the directions are only 2 (just like a scalar) the magnitudes can be ordered...right?[/quote]
Another example, in polar coordinate system [itex]3 cos \theta[/itex]
In polar coordinate system i.e
I've seemed to forget vectors completely...
  • #31
That is not a vector, that is a scalar function of theta.
You misunderstand what a vector is in polar/cylindrical coordinates. A vector in polar coordinates is not defined by a magnitude and an angle, that would only give you the subset of vectors that originate at the origin. Let's say I have a vector from the point (1,1) to (0,1). Your definition of magnitude and angle would not be able to represent this vector using the polar/cylindrical coordinate basis vectors. In cartesian coordinates the vector is (-1,0) from the point (1,1). In polar coordinates, the vector is (-1/\sqrt{2},1/\sqrt{2}) from the point (\sqrt{2},\pi/4). The location of points in polar coordinates is defined by magnitude and angle, but not vectors.
A general vector is made of a magnitude and a direction and it usually has a location. The magnitude and direction are represented as a combination of orthonormal bases that span the coordinate space. This way we can use vector operations to manipulate the vectors in such a way that will always give us a vector in our coordinate space without a lot of calculations. The use of the basis vectors makes the vector operations much simpler. Think how you would have to add the vectors, in Cartesian coordinates, (1,0) and (0,1). If you just described them mathematically as a magnitude and angle, then you have to do the conversions to see how their directions add. Now displace these vectors off of the origin and the conversions become more complicated.
  • #32
Yes, I remember you said …
dE_logics, the most important thing about vectors is that they "add like vectors" …
you can use the parallelogram rule, or just add the Cartesian (ie, x y z) coordinates …
but the thing that distinguishes a vector from a scalar or a spinor (maybe you haven't come across them yet) is the way they add.
Now, adding polar coordinates is really difficult (eg what is (r,θ) + (s,φ)?), and almost impossible if they don't start from the same point.
But adding Cartesian coordinates is really easy … (x,y,z) + (a,b,c) = (x+a,y+b,z+c) … even if they don't start from the same point.
(Same for cross product and dot product.)
Polar coordinates are a useful calculation tool in some physical situations (usually where there's a "central" force), but usually they're a nuisance (and that's in 2D … in 3D it's even worse :wink:).
If you've "forgotten vectors completely" and are trying to re-learn them, then concentrate on Cartesian (ie x y z) coordinates. :smile:
  • #33
You can order vectors, read some order theory... Also that was a one dimensional vector, which can be ordered really easily so then they absolutely have signs even with the most layman use of the word.
Anyway, that have nothing to do with this thread at all, the numbers inside vectors have signs and as such you could say that the vector as a whole have "signs".Anyhow, the most important question in this topic is:
dE_logics, how much maths have you read? To me it sounds like you haven't even read any linear algebra since you haven't seen the standard notations for vectors etc. This is really important so that we can understand what problem you might have.
  • #34
I suggest you follow your own advice. The best one can do in general with vector spaces is to impose a quasiorder. You cannot impose an ordering (i.e., a total order) on vectors of dimension 2 or higher.
What is the sign of [tex]{\boldsymbol x} = \hat {\boldsymbol i} - \hat {\boldsymbol j}[/tex]?
  • #35
Yeah, using solely polar convention, we won't know the direction at which the vector 'points'.
Its like a line segment in a Cartesian coordinate system.
aaaa...sorta didn't get that, never mind :smile:
i.e algebraic addition is different...right?
You're right!
Yeah I did lots of questions on that (though not without understanding)...phaser diagrams are an example, in representing complex numbers etc...
  • General Math
  • General Math
  • Other Physics Topics
