Calculating Vector Sum: 40 ft and 14 degrees south of west - Vectors J and K
  • Thread starter gurmeet97
  • Tags
    Vectors
In summary, Vector J has a magnitude of -30 ft and a direction of 13 degrees north of east. Vector K has a magnitude of +36 ft and a direction of 54 degrees north of east. Their sum has a magnitude of +38 ft and a direction of 27 degrees south of west.
gurmeet97
Vector J has a magnitude of 28 ft and a direction of 34 degrees west of north. Vector K has a magnitude of 48 ft and a direction of 20 degrees south of east. Find the magnitude and direction of their sum.
a) 30 ft and 13 degrees north of east
b) 36 ft and 54 degrees north of east
c) 38 ft and 27 degrees south of west
d) 40 ft and 14 degrees south of west
Square root of 28^2 plus 48^2= 55 ft
34 degrees West of North=304 degrees
20 degrees south of east=160 degrees
304 plus 160= 464
464/2= 232 degrees
38 degrees west of south
Hi gurmeet97. Welcome to Physics Forums!
Resolve each of the two vectors J and K into x and y components, and then sum the components. This will give you the x and y components of their resultant.
Chet
304 plus 160= 464
464/2= 232 degrees
It's not clear what convention you are using to measure angles. The standard convention is that east is zero degrees (or 360 degrees after a full circuit) and angles are measured positive counterclockwise, so that north is 90 degrees, west is 180 degrees, and south is 270 degrees.
You should draw your vectors and the resultant to check your answer. (which isn't one of the choices anyway).
Try to break down both vectors in their x and y components.
"Square root of 28^2 plus 48^2 = 55 ft"
Wrong, this would only be valid if the vectors were perpendicular to each other.
My prof used to do that too. 0 is still east, but all your angles aren't necessarily give off the east direction, its just an extra step.
Oh wait, I see what you mean. I didn't catch ops "solved" directions. It appears as though op is starting west and measuring ccw which will give them -1 of what they want.
1. How do I calculate the vector sum?
The vector sum can be calculated by using the Pythagorean theorem and trigonometric functions. First, find the horizontal and vertical components of each vector using the given magnitude and direction. Then, use the Pythagorean theorem to find the magnitude of the resultant vector, and use trigonometric functions to determine its direction.
2. What is the Pythagorean theorem and how do I use it?
The Pythagorean theorem states that in a right triangle, the square of the length of the hypotenuse (the side opposite the right angle) is equal to the sum of the squares of the other two sides. In this case, you can use it to find the magnitude of the resultant vector by finding the square root of the sum of the squares of the horizontal and vertical components.
3. How do I find the horizontal and vertical components of a vector?
To find the horizontal and vertical components, you can use trigonometric functions. For example, to find the horizontal component of a vector with a given magnitude and direction, you can use the cosine function by multiplying the magnitude by the cosine of the direction angle. Similarly, you can use the sine function to find the vertical component.
4. Can I use a calculator to calculate the vector sum?
Yes, you can use a calculator to perform the necessary mathematical operations for calculating the vector sum. However, make sure to use the correct units and convert them if necessary.
5. What is the direction of the resultant vector?
The direction of the resultant vector can be determined by using trigonometric functions. For example, if the horizontal and vertical components of the resultant vector are known, you can use the inverse tangent function to find the direction angle. In this case, the direction is 14 degrees south of west.
14K
