Vectors or not?
I have a general question on presenting physics work:
When is it appropriate to use vector (bold) notation? I understand the difference between vectors and scalar quantities, and always used to think an equation with a vector on the LHS needed to have a vector on the RHS, but in writing up a recent question, had this equation:
E[tex]_{kin}[/tex]=1/2mv[tex]^{2}[/tex]
which I then use to produce an equation involving momentum, p, and then the final result which is a dimensionless quantity.
Now I know energy is not a vector quantity. Does that mean it is wrong to put the velocity reference in bold?
The same goes for the expression involving momentum:
E[tex]_{kin2}[/tex]=(p[tex]^{2}[/tex])/2(m+M)
is it wrong to have the p in bold?
Thanks for any advice.
Tom
D H
Staff Emeritus
Insights Author
15,259
679
[Equation corrected]
[tex]E_{kin}=\frac1 2 \,\frac{p^2}{m+M}[/tex]
In my opinion, yes. If you want to use a vector you would need to be a bit more verbose:
[tex]E_{kin}=\frac1 2 \,\frac{\mathbf p\cdot \mathbf p}{m+M}[/tex]
or
[tex]E_{kin}=\frac1 2 \,\frac{||\mathbf p||^2}{m+M}[/tex]
The only time you need to be verbose like that is when you are already using (in this case) a scalar p that denotes something other than the magnitude of the momentum vector. Otherwise, use of a unbolded symbol, particularly when squared, indicates the magnitude of the corresponding vector. It's pretty clear, and that is the standard usage in texts and journals. (Suppose you write a paper in which p denotes momentum but p denotes pressure. This paper will probably come back with some scathing review comments along the lines of "Don't do that! You confused me, and I know the subject.")
Doc Al
Mentor
44,642
966
In an expression for KE, I would not use bold (or any other notation) to represent velocity or momentum as vectors, since only the magnitudes of those quantities are needed.
Realize that: [tex]v^2 \equiv \vec{v} \cdot \vec{v}[/tex]
Edit: While I was daydreaming, D H beat me to it.
Thanks all.
Much appreciated.
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
