Homework Help: Vectors, poition vectors,
  1. Sep 3, 2010 #1
    a) Masses, m1,m2,.....mk are at points P1,P2,.....Pk with position vestors P1,P2,.....Pk (these should be in bold) respectively. The position vector g of the centre mass is given by: (m1+m2+.....mk)g=m1,p1+m2p2+.....+mkpk
    Find the position vector of the centre of mass of the masses 3,4, and 5kg placed at:
    P1=(1,-1,1), P2=(2,-1,1) and P3=(-1,0,2) respectively.
    Not sure how to do this
    b) Determine the value of lambda that will make the following points coplanar:
    (1,0,-3), (1,1,-2) and (lambda,-1,0).
    Not sure how to do this either
    c) Find a unit vector normal to the curve 2cosx-3e^x=y^2-1 at the point where x=-pi/4
    Not sure how to do this as well
    Any help would be great, even if its just a point in the right direction to start with
  3. Sep 3, 2010 #2
    CompuChip
    You have been given the equation (let me work it out in LaTeX):
    [tex] (m_1 + \cdots + m_k) \vec g = m_1 \vec p_1 + \cdots + m_k \vec p_k [/tex]
    from which you can solve for the position vector g:
    [tex] \vec g = \frac{ m_1 \vec p_1 + \cdots + m_k \vec p_k }{m_1 + \cdots + m_k}[/tex]
    All you have to do is write it down for your specific case where k = 3 and plug in the values.
    For b, what does it mean if three points are co-planar?
    For c, even if you have no clue, you can calculate the y-coordinate of the point they are talking about. Then you can look up how you can find a normal vector to a curve, at a given point (it has to do with the tangent vector to the curve).
