gamer1319
- 12
Vectors question- CONFUSED!
Blabla
Blabla
Vectors are physical quantities that have both magnitude (size) and direction. They are used in science to represent the movement or force of an object, as well as the direction and magnitude of electromagnetic fields and other physical phenomena.
The magnitude of a vector can be calculated using the Pythagorean theorem, which states that the square of the hypotenuse (longest side) of a right triangle is equal to the sum of the squares of the other two sides. In the case of a vector, the magnitude is equal to the square root of the sum of the squares of its components.
A scalar is a physical quantity that has only magnitude (size) and no direction, such as temperature or mass. A vector, on the other hand, has both magnitude and direction, and is used to represent physical quantities like displacement, velocity, and force.
To add or subtract vectors, you must first determine their components (magnitude and direction) and then use the appropriate mathematical operations. For example, to add two vectors, you add their components together, and to subtract two vectors, you subtract their components.
Yes, vectors can have negative magnitudes. This indicates that the vector is pointing in the opposite direction of its positive counterpart. For example, a velocity vector with a magnitude of -10 m/s would be moving in the opposite direction of a velocity vector with a magnitude of 10 m/s.
