Understanding Zero Velocity and Non-Zero Acceleration: Explained
In summary, the conversation is discussing the concept of zero velocity and non-zero acceleration. It is clarified that this situation can occur when an object is thrown vertically upwards and reaches the top of its trajectory, as well as in other situations such as a boat accelerating against a river current or a plane being overtaken by a faster plane. The concept is further explained using equations and graphs. It is concluded that the confusion arose due to a misunderstanding of the relationship between acceleration and velocity.
pttest
I heard it would be possible to have zero velocity & non zero acceleration (I know the opposite situation where there is velocity (constant), but zero acceleration). Could anyone please give me a clue on this?
Thanks in advance
Throw a ball upwards.
Hi pttest! :smile:
When you throw a ball vertically upwards, and catch it again on the way down, it has the same acceleration (g downward) the whole time, but zero velocity when it reaches the top. :wink:
The prior post documents the only practical type case I can think of at the moment. A similar situation without velocity reversal could be a boat accelerating against a river current...as observed from shore.
An abstract situation might be at the moment when a distant observer sees a spaceship accelerating towards him and when the velocity reaches the observed cosmic expansion speed at the location of the spaceship, the observer would measure zero velocity...
How about an accelerating plane being overtaken by another higher fixed speed plane: at the moment the speeds are equal, velocity would be zero.
but so what??
I don't understand.. Velocity is the rate of change in position. Acceleration is the rate of change in velocity.
If the velocity isn't changing how can the acceleration be anything other than 0?
uhm, no. throwing a ball upwards does not produce zero velocity and nonzero acceleration. throwing a ball upwards constantly accelerates it at -9.8 meters per second per second.
davidsnider is absolutely right.
No, he's not. And neither are you.
However, here's your chance to prove yourself: If the acceleration is 0 at the top of the ball's trajectory and 9.8 m/s2 on the way back down, at what point in time, t, does the acceleration become nonzero and what is the acceleration at that point?
Er... the velocity is zero only for an instant. It continues to change!
The ball being thrown up has a constant acceleration, which is downwards. It's velocity is changing, but changing at a constant rate! At some point, for a moment, it attains zero velocity.
Zz.
Zz.
OK, you can have an instantaneous velocity of 0, but at that point isn't your instantaneous acceleration also 0?
Why? The velocity is changing!. That's the definition of it having an acceleration, which is -g!
Zz.
I'm not quite sure why this is a problem, since this is standard high school physics.
[tex]a = \frac{dv}{dt} = -g[/tex] (using the convention that upwards is positive),
[tex]v = -g\int{dt}[/tex]
[tex]v = -gt + v_0[/tex]
where [itex]v_0[/itex] is the initial velocity, and we let this to be positive since it was tossed upwards.
Now PLOT that as a function of t. You'll see that as gt grows in value, v will become smaller, until at some point, [itex]-gt + v_0[/itex] is zero! But look at how this was derived. It was derived for a constant acceleration of -g! Throughout the whole motion, the acceleration is a constant!
Zz.
Try the oscillating motion of a mass in a simple mass-spring harmonic oscillator. At the maximum extension, the mass temporarily has a zero velocity, but the acceleration is maximum.
Zz.
I understand now. Thanks.
Thanks in advance
The problem is simply the way in which you phrased this statement.
Observe:
pttest said:
I heard it would be possible to have zero instantanous velocity & non zero acceleration (I know the opposite situation where there is velocity (constant), but zero acceleration).
excuse me. Zz corrected what i was trying to say.l
The problem here is that you have a fundamental misunderstanding of what acceleration means in relation to velocity. Consider a curve of velocity vs. time. At some time, t, the instantaneous velocity is zero. The acceleration is the slope of the velocity curve at time t. You are confusing a value on a curve with its slope.
1. What is zero velocity?
Zero velocity refers to the state of an object when its speed is equal to zero. In other words, the object is not moving and remains at rest.
2. What is non-zero acceleration?
Non-zero acceleration refers to the change in an object's velocity over time. This means that the object is moving and its speed is either increasing or decreasing.
3. What is the difference between zero velocity and non-zero acceleration?
The main difference is that zero velocity refers to the speed of an object at a specific moment in time, while non-zero acceleration refers to the change in an object's velocity over time. In other words, zero velocity indicates that the object is at rest, while non-zero acceleration indicates that the object is in motion.
4. Can an object have zero velocity and non-zero acceleration at the same time?
No, an object cannot have zero velocity and non-zero acceleration at the same time. This is because if an object has zero velocity, it means that it is not moving, and therefore its acceleration must also be zero. In order for an object to have non-zero acceleration, it must be in motion.
5. How is zero velocity and non-zero acceleration represented in a motion graph?
In a motion graph, zero velocity is represented by a horizontal line at the point where the object's velocity is equal to zero. Non-zero acceleration is represented by a curved line, with the slope of the line indicating the object's changing velocity over time.
  • Mechanics
  • Mechanics
