Velocity addition formula
  • Thread starter name123
Imagine two space ships each with thrusters that can accelerate them .1c or .3c almost instantly. The velocity addition formula indicates that if one space ship applied the .1c thruster 3 times then if c is estimated to be 300,000,000 m/s the velocity of the ship after the accelerations the ship will be approximately 87,669,903 m/s. Which is less than the 90,000,000 m/s which would have been achieved using the .3c thruster. So does this mean that the energy needed to go .1c in space < (energy needed to go .3c in space)/3?
Also given the formula (u + v) / (1 + ((u*v)/(c*c)))
Is it saying it is more expensive to try to go .1c then .4c or .4c then .1c than go .2c then .3c or .3c then .2c (because u + v = .5c in both cases, but the u * v = .04c with the .1c and the .4c, but .06c with the .2c and the .3c) but you would achieve a higher velocity?
Answers and Replies
DEvens
Education Advisor
460
Is it saying it is cheaper to go .1c then .4c or .4c then .1c than go .2c then .3c or .3c then .2c (because u + v = .5c in both cases, but the u * v = .04c with the .1c and the .4c, but .06c with the .2c and the .3c).?
I really do not know if it is saying that because I cannot understand what you said.
What it is asking is, is the energy required to accelerate to 0.1C less than one third the energy required to accelerate to 0.3C?
It's kind of a poor question because you can't really get it from the information provided. In order to compare energy for the different things you would need to calculate energy. And you can't get that from the velocity composition formula.
The question in the text previous to the text you quoted was about whether it required less energy to go accelerate to 0.1c was less than one third the energy required to accelerate 0.3c. The text you quoted was about whether it required less energy to try to accelerate 0.4c and then 0.1c _or_ 0.1c then 0.4c vs. trying to accelerate 0.2c and then 0.3c _or_ 0.3c then 0.2c. I didn't realise the question was so poor, I thought there might be a general principle like it requiring more energy to achieve a greater velocity. So you could look at the velocity achieved by using the equation and then make statement about whether there was a lower energy route to achieving the lower velocity than the lowest energy route for achieving the higher velocity. Was I mistaken?
DEvens
Education Advisor
460
The velocity composition formula does not tell you anything about the energy required to achieve those velocities.
Also, the question asks about the relative energies of velocities 0.1 and 0.3. But the information given refers to velocities 0.1 and 0.292 (the speed just less than 90 million m/s). So it's not the right speeds. And it does not tell you what energy is required of the engines to achieve those speeds.
And in order to properly understand the energy required to achieve a given speed you need to be doing the full calculation. Even at non-relativistic velocity there are surprises. Example: If you have a rocket motor that lets you add 1 m/s to your speed, and you accelerate from 0 m/s to 1 m/s, and your ship masses 100 kg, then you added 1/2 mv^2 = 50 Joules of kinetic energy. But if you start at 1 m/s, and do the same thing going from 1 m/s to 2 m/s, you have gone from 50 Joules at 1 m/s,
to 200 Joules at 2 m/s. And so you have added 150 Joules to your kinetic energy. How can that be? How can your rocket motor give you three times as much kinetic energy doing the same thing? Once you figure that one out, then try the relativistic question again.
15,912
Since the energy per unit rest mass can be computed from the velocity, knowing the velocities does tell you something about the energy required. The problem is that the OP is making an incorrect assumption about the relationship between velocity and energy. See below.
Note that for this to be true, the 0.1c thruster, when it fires the second and third times, must change its ship's speed by 0.1c relative to its current rest frame, not relative to the original rest frame. (When it fires the first time, the original rest frame and the ship's current rest frame are the same.)
Not really. The statement just quoted is true, but not for the reason you think.
Energy is not a linear function of velocity. The energy of an object with rest mass ##m## moving at speed ##v## is ##m c^2 / \sqrt{1 - v^2 / c^2}##. The kinetic energy (what you have to add to move the object from rest to speed ##v##) is just that total energy minus the rest energy ##m c^2##. If you calculate the kinetic energy (or better, the kinetic energy per unit rest mass) for ##v = 0.3c##, you will see that it is a lot more than three times the kinetic energy for ##v = 0.1c##.
In fact, if you calculate the kinetic energy per unit rest mass for the speed the ship with the 0.1c thruster will be at after the thruster fires three times (87,669,903 m/s, or about 0.292c), you will find that that is also a lot more than three times the kinetic energy per unit rest mass for a speed of 0.1c. (This is just the relativistic version of what DEvens was telling you at the end of post #4.) So clearly the relationship between speed and the energy required to reach that speed is more complicated than you have been assuming. You are leaving out a key factor. Rather than give it explicitly here, I'll suggest that you google "relativistic rocket equation".
I'm now just trying to check whether I'm understanding it correctly or whether I'm making any any mathematical mistakes I'm making or logical errors.
Imagine spaceships A, B, and C have acceleration switches, which in their rest frame will increase their speed by either 0.1c or 0.2c or 0.3c or 0.4c depending on the switch. Each takes the ship from 0 to the velocity it says on the button from the perspective of the rest frame it was in before it pressed the button. What I'm interested in is the velocity achieved from spaceship A's perspective. The energy to accelerate the each ship after an acceleration button has been pressed can be imagined to come from a ship behind which is follows it through each acceleration, and be measured by each ship to be the same each time. I'm not concerned with the fuel on the ship behind.
T = 0 : B applies 0.1c acceleration switch, C applies 0.3c acceleration switch.
T = m : B applies 0.1c acceleration switch again.
T = m + n : B applies 0.1c acceleration switch again.
I'm assuming that from B's perspective the same amount of energy received is the same each time it presses the button, because I'm assuming the theory allows B to consider itself to be at rest prior to pressing the button, and that the same energy would be required for the same effect each time from its perspective. And I'm assuming from B's perspective each press of the button takes it to 0.1c (30,000,000m/s) faster than prior to when it pressed the button, and at the end of three presses it has increased in velocity 0.1c each time, and so i at 90,000,000 m/s at the end of 3 presses of the "0.1c" button. From A's perspective the 3 presses took B to 87,669,903 m/s rather than the 90,000,000 m/s that would have been expected if each "0.1c" fuel consumption had produced a 30,000,000 m/s increase. Presumably A will agree with B about the energy received for each acceleration. So from A's perspective the amount of energy required to increase velocity has increased. I'll just run through that again, because maybe the way I write things isn't always clear. At any point prior to an acceleration B could have considered itself the rest frame (assuming rest frame history doesn't matter), and so the effect of pressing the button will appear the same each time, including the amount of energy it then receives to do it. Presumably A can agree with B about the energy consumed to accelerate it to its state, it would just disagree about the increase in velocity achieved per press of the button. If so then from A's perspective the amount of fuel required to increase velocity has increased, as those three same percentages being used up don't achieve three times the velocity increase. So a press of the ".3c" acceleration switch would require more energy as 90,000,000 m/s is a higher velocity than the 87,669,903 m/s that results from the consumption of 3 ".1c" units. I'm assuming the spaceships are efficient.
If my understanding is ok, then given the formula
it is clear that
(0.4c + 0.1c)/(1 + ((0.4c * 0.1c) / (c * c))) > (0.2c + 0.3c) / (1 + ((0.2c * 0.3c) / (c * c)))
from both the numerators being the same and the denominator of the smaller being bigger when the equation is considered as a numerator expression and a denominator expression.
The equation seems to be saying that if Observer A wanted to achieve a higher velocity and could only press each button once, then it would be better for it to press the "0.4c" button followed by the "0.1c" button, rather than the "0.2c" button followed by the "0.3c" button. The extra energy in a "0.4c" unit compared to 4 "0.1c" units outweighs the extra energy of a "0.2c" unit and a "0.3c" unit when compared to a "0.1c" unit. Have I misunderstood?
15,912
No, he won't--at least not for any acceleration after the first. See below.
That's true anyway, because, as already pointed out, energy is not a linear function of velocity. The amount of energy A sees B receiving in the second acceleration is larger (quite a bit larger) than the amount of energy A sees B receiving in the first acceleration, even though A sees B's speed increase less in the second acceleration than in the first.
However, in each case, B sees himself receiving the same amount of energy (relative to his instantaneous rest frame before each acceleration starts). So for the first acceleration, A and B will agree on the energy B receives; but for the second, and even more for the third, A will see B receiving more energy than B sees himself receiving. And this is true even though A sees B's speed increasing less for the second and third accelerations than B sees his own speed increasing.
I had said "Presumably A will agree with B about the energy received for each acceleration." to which you replied
I had also said: "So from A's perspective the amount of energy required to increase velocity has increased." To which you replied:
If the fuel had been on-board space ship B, are you saying that A would be disagreeing what % had been used up in the 3 thrusts?
15,912
No. The fuel used up is a direct observable (at least, it is if you use an appropriate invariant measure of how much fuel is used, such as how much rest mass of fuel is used). But the fuel used up is not the same as "the energy added to spaceship B" without qualification, because the latter is frame-dependent and the former is not.
The direct relationship will be between the rest mass of fuel used up for a given thrust, and the energy added to spaceship B, in the instantaneous rest frame of B when the thrust starts. (This is assuming the thrust is over a short enough time.) But as noted, that will not be the same as the energy added to spaceship B, in spaceship A's rest frame.
So they'll agree on the amount of fuel used up, but disagree on the amount of energy that using that fuel would provide the system/spaceship?
15,912
Yes. Again, energy is frame-dependent.
I hadn't realised that the energy released from chemical reactions was said to change with velocity. But have used the energy equation you provided and can see it on a spread sheet, so thanks :)
How is it tested btw?
15,912
The energy of anything depends on the coordinates you are using. The chemical reactions themselves don't change.
15,912
How is what tested? If you mean, have we run chemical reactions on a spaceship moving at relativistic speed relative to Earth, and tried to measure their energies from Earth, of course not; that's well beyond our current or near-future technology. Chemical reaction energies are measured in the rest frame of the reaction vessel. To figure out what they would be in a frame in which the reaction vessel was moving at relativistic speed, you would use the equations of SR to calculate it.
If you mean, how are the laws of special relativity tested, they've been tested thousands of times in particle accelerators and other devices all over the world, not to mention plenty of experiments specifically testing key postulates. See here for a comprehensive review:
http://math.ucr.edu/home/baez/physics/Relativity/SR/experiments.html
I meant how can they tell that it wasn't that the energy given off was the same but the resultant increase in velocity was different, and that actually it was a different resultant velocity + the energy given off was different.
15,912
I don't understand what this means. Once you have chosen a frame, the relationship between energy and velocity is fixed by the equations of SR, which have been thoroughly tested. So testing the equations of SR is testing that relationship.
Vanadium 50
Staff Emeritus
Education Advisor
2021 Award
28,250
12,939
Name123, before you go too far down that rabbit hole, you do realize that energy is frame-dependent even in Newtonian mechanics, right?
Likes Nugatory
No I didn't, I had assumed that energy wasn't relative. That there was a certain amount of energy "in play" so to speak in the universe, and that the amount was thought to be objective.
A.T.
2,898
Classical kinetic energy has velocity right in the formula, and that velocity is obviously frame dependent. When you accelerate your car from 0 to V in the ground frame, it's velocity changes from U to U+V in some other frame. The change in kinetic energy is different in each frame, but the fuel burned is the same.
15,912
There are things that are conserved in our relativistic universe, but "energy" is not one of them. For the scenario under discussion here, the key conserved quantity is 4-momentum, or, equivalently, invariant mass; the invariant mass of the whole system (all the spaceships and all the fuel used to accelerate them) is constant (and is equal to the initial mass of everything in the frame, spaceship A's frame, in which it all starts out at rest).
But there was absolute motion, and I would have thought the equation was supposed to work with the actual velocity. So while you could use frames of reference, they wouldn't actually be expected to change the energy. Instead I would have thought it would have been interpreted that an entity in a frame of reference in motion could be mistaken about the true velocity of an object in a frame of reference which had a higher velocity in the same direction as its, and therefore miscalculate its true energy. Given that there was the idea of absolute motion.
By conserved I assume you mean more than it will keep its value over time, such as the conservation of energy of a system. You mean conserved between rest frames also. With regards to energy you seem to be saying that relativity suggests that there is no underlying physical reality which has energy as an objective property. Is that what you are saying?
Nugatory
Mentor
13,907
7,352
No, it always works with relative motion. If I shoot a .1 kg bullet with a muzzle velocity of 1000 meters/second at a 1000 kilogram target, I can use a frame in which the target is at rest (total kinetic energy is ##5\times{10}^4## Joules, or a frame in which the bullet is at rest and being smacked by a fast-moving target (total kinetic energy is ##5\times{10}^8##, or a frame in which the target is moving at 100000 meters/second and the bullet is moving at 99000 meters/second or 101000 meters/second (you can calculate the kinetic energy in those cases for yourself).
No matter how I do it, the damage done to the target (that is, the difference between the pre-impact and the post-impact kinetic energy - this difference is the amount of energy that went into damaging the target) will be the same.
You might want to google for "Galilean relativity".
There is a difference though is there not from being able to work out the damage done to the target from any rest frame, and metaphysically considering a physical reality for example not to have energy as an objective property. It just seems strange to throw away the concept when being able to use the equations to work out the damage done in itself doesn't require it.
15,912
There is no such thing as absolute motion in relativity. All motion is relative. If you are assuming there is absolute motion, that is probably a primary reason for your confusion.
Strictly speaking, "conserved" means "does not change over time", and "invariant" means "has the same value in all reference frames". Invariant mass of the total system in the example in your OP has both of those properties.
The term "underlying physical reality" isn't a scientific term; it's too vague. What I am saying is simply that "energy", in relativity, is neither conserved nor invariant (with the meanings of those terms that I gave above). That is a precise scientific statement.
Nugatory
Mentor
13,907
7,352
Do you feel the same way about "height"? My kitchen counter is about 101 meters above sea level and my kitchen floor is about 100 meters above sea level. The counter is also -2 meters from the ceiling while the floor is -3 meters from the ceiling. No matter which view I adopt, I'll get the same result when I calculate the damage to an object that falls off the counter and lands on the floor.
15,912
The damage done isn't a function of "energy" in any absolute sense (since there is no such thing). It's a function of energy relative to the target. The latter is an invariant even though energy in general is frame-dependent.
I was thinking of objective relative amounts, so I wasn't really thinking about variable starting points or scales. What I meant was that objectively A has more energy than B, as opposed to the answer depending on the frame of reference. Like the counter > floor in height no matter which of the views you presented you adopt.
You are saying that there is no such thing as energy, or that there is no such thing as absolute energy?
  • #31
Nugatory
Mentor
13,907
7,352
That's not necessarily true - no law requires that I choose the direction of increasing height values in such a way that they increase in the direction of the Earth's sky. A physicist on Mars is unlikely to care about the height of either my kitchen floor or my kitchen counter, but if he did then (depending on where Earth and Mars happen to be at the moment), he would say that the counter is 54,600,000,000 meters high and the floor is 54,600,000,001 meters high.
The frame-independent truth that you can take to the bank is that the the gravitational potential at the counter is less than that at the floor by a particular amount. From this, you can calculate the result of any experiment involving the floor and the counter.
  • #32
485
I specifically stated that what I was saying regarding the height related to the two options you had previously given. And it was true for them. I thought on Earth height roughly did mean in the direction of Earth's sky. I couldn't think of a counter example where it wouldn't, in English anyway. Though I can see that there would be problems in comparing heights on Mars and Earth, but I guess if you were to have some definition, then maybe it would fix the comparison answer.
  • #33
38,124
15,912
There is no such thing as absolute energy.
  • #34
DEvens
Education Advisor
460
Wow. As with so many threads connected to relativity, this is experiencing rather severe topic drift. The original question has been left behind and seemingly is forgotten, while people are talking past each other about quite tangential ideas.
Let's get back to the original question.
Even at low speeds such as 1 m/s to 3 m/s, would you expect the energy to get to 3 m/s to be three times the energy to get to 1 m/s? If you had a rocket that could give you three 1 m/s kicks, do you expect your kinetic energy to be three times as much after three 1m/s kicks as it was after one 1 m/s kick?
Of course, the answer is that at 3 m/s you have 9 times as much kinetic energy as at 1 m/s. Not even close to 3 times as much. So what happens to conservation of energy? Surely you will burn just about three times as much fuel to get to 3 m/s as you would to get to 1 m/s. (With some minor differences because the expulsion of stuff out the back of the rocket changes its mass.) How can the rocket be producing more kinetic energy from later changes in velocity?
0 to 1 increases by v^2 = 1
1 to 2 increases by 2^2 - 1^2 = 3
2 to 3 increases by 3^2 - 2^2 = 5
Well, of course, the answer is that the rocket is not the only thing with kinetic energy. If the rocket masses 100 kg, and flings 1 kg out the back at 100 m/s to gain 1 m/s in velocity, the reaction mass winds up with kinetic energy as well. If the rocket starts at 1 m/s then the reaction mass also starts at 1 m/s, and so winds up going 99 m/s backwards instead of 100 m/s. If you work out the total change in kinetic energy you find that it is invariant under changes of velocity. (Don't forget to include the starting kinetic energy of the ship and the reaction mass.)
So the fact that the velocity composition means three increases of 0.1 c does not quite get you to 0.3 c really isn't helping understand the kinetic energy of the situation. It's a complication on the end, but there are more fundamental ideas at work here.
  • #35
485
Well thanks for the help everyone gave there, that's cleared a few things up for me. I hadn't realised that energy was being considered truly relative, but I guess it follows from the metaphysical assumption that presentism isn't true.
Related Threads on Velocity addition formula
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
