What Is the Bird's Speed After Swallowing the Insect?
In summary, the bird's speed immediately after swallowing the insect is 4.5 m/s. This can be calculated using the conservation of momentum equation, where the initial momentum of the bird and insect is equal to the final momentum of the bird after swallowing the insect. The direction of the bird's velocity will depend on the perspective and can be expressed in degrees.
jeeves_17
A 300 g bird flying along at 6.0 m/s sees a 10 g insect heading straight toward it with a speed of 30m/s. The bird opens its mouth wide and enjoys a nice lunch. What is the bird’s speed immediately after swallowing?
Relevant equations
Jx = m(Vx)f - m(Vx)i
Jy = m(Vy)f - m(Vy)i
Given
m(b) = 0.3 kg
v(b) = 6.0 m/s
m(i) = 0.01 kg
v(i) = 30 m/s
The attempt at a solution
Jx = (0.01)(30) - (0.3)(6.0)
= 0.12kg.m/s
0.12kg.m/s * 1/0.3kg = 0.4 m/s
.3 * 6 - .01 * 30 = (.3 + .01) * v
p1 + p2 = p1' + p2'
forget the components in this problem. the objects are traveling in a linear path, so a negative value and a positive value denote the direction. You can assign what each equal, though, just as long as you keep it consistent throughout the problem.
P1 = m1*v1
= (0.3)(6.0)
= 1.8
P2= m2*v2
= (0.01)(30)
=0.3
P1 +P2 = P3
1.8 +0.3 = P3
P3 = 2.1
P3 = m3v3
v3 = p3/m3
= 2.1/0.31
= 6.7741935
= 6.77 m/s?
jeeves_17 said:
P1 = m1*v1
= (0.3)(6.0)
= 1.8
P2= m2*v2
= (0.01)(30)
=0.3
P1 +P2 = P3
1.8 +0.3 = P3
P3 = 2.1
P3 = m3v3
v3 = p3/m3
= 2.1/0.31
= 6.7741935
= 6.77 m/s?
No. p1 and p2 are vectors and in this problem they point exactly opposite of each other
Think about it this way: this interaction happens ONLY on the x axis, so only use the x axis.p1 = .3 * 6 * cos(0)
p1 = .3 * 6 * 1
p1 = 1.8
p2 = .01 * 30 * cos(180)
p2 = .01 * 30 * -1
p2 = NEGATIVE .3
p1 + p2 = p1' + p2'
1.8 + -.3 = (.01 + .3) * v(the v after the eating happens)
if v is negative, then the answer will be at 180. if positive, 0. (remember, only because i defined 0 degrees as positive velocity and 180 degrees as negative velocity)
The answer is 4.84 m/s, 0 degrees or "in the direction the bird was flying"The problem doesn't define a perspective, so you could say the bird was flying from right to left and all that would happen is the answer will be 180 degrees instead of 0. I would just include the degrees and the words to explain your perspective. Just think about it. You could watch this collision from any perspective. The result won't change, only the way to express it.
just another way to do this is:
m1*(vf)1 + m2*(vf)2 = m1*(vi)1 + m2*(vi)2
because the bird swallows the insect (vf)1 and (vf)2 are going to be the same
(m1 + m2)*vf = m1*(vi)1 + m2*(vi)2
then solve for vf
vf= m1*(vi)1 + m2*(vi)2 divided by (m1 + m2)
to make things clear let's say the bird is flying in the positive direction, and since the insect is flying is the opposite direction of the bird making its velocity negative
sooo..
vf = (0.03kg * 6.0m/s) + (0.01kg * -30.0m/s) divided by (0.31kg)
vf= 4.8m/s
What is the definition of velocity after collision?
Velocity after collision refers to the speed and direction of an object after it has collided with another object. It takes into account the momentum and energy of both objects involved in the collision.
How is velocity after collision calculated?
Velocity after collision is calculated using the conservation of momentum and energy equations. This involves taking into account the mass, velocity, and direction of both objects before the collision, as well as the coefficient of restitution, which represents the elasticity of the collision.
What factors can affect the velocity after collision?
The velocity after collision can be affected by various factors such as the masses and velocities of the objects involved, the angle of collision, and the coefficient of restitution. Other factors like air resistance and friction can also play a role in determining the final velocity.
Can the velocity after collision be greater than the initial velocity of the objects?
Yes, the velocity after collision can be greater than the initial velocity of the objects if the collision is elastic, meaning that the objects bounce off each other with no loss of kinetic energy. However, in most real-life collisions, some energy is usually lost due to friction and other factors, resulting in a lower velocity after collision.
How is the direction of the velocity after collision determined?
The direction of the velocity after collision is determined by the angle of collision and the initial velocities of the objects. In a head-on collision, the direction of the velocity after collision will be the same as the initial velocity of the object with the greater mass. In oblique collisions, the direction will depend on the angle of collision and the initial velocities of both objects.
12K
10K
