Velocity and acceleration problem
In summary, the position vector of a particle at a given time is represented by r = icos t + jsin t +kt. The magnitude of its velocity and acceleration vectors are both constant, with a magnitude of √2 and 1 respectively. However, the particle's motion is not at a constant velocity, as its direction continuously changes. When plotted on an xy-plane, the particle follows a circular path with increasing z-coordinate over time. Therefore, the motion can be described as a circular motion with a constant rate of increase in the z-direction.
gtfitzpatrick
379
the position vecter r of a particle at a time t is
r = icos t + jsin t +kt show that the magnitudes of the velocity and acceleration vectors are constant. Describe the motion
velocity = i(-sint) + j(cost) +k
magnitude is [tex]\sqrt{(-sint)^2 + (cost)^2 + 1}[/tex] = [tex]\sqrt{2}[/tex]
acceleration = i(-cos t) - j(sin t)
magnitude is [tex]\sqrt{(-sint)^2 + (-cost)^2 }[/tex] = [tex]\sqrt{1}[/tex] = 1
but I am not sure how to discribe the motion, at first i was thinking of an object moving at a constant velocity of [tex]\sqrt{2}[/tex] and to move at a constant velocity it acceleration isn't changing so should that not mean the acceleration is 0 instead of 1?
You've shown that the particle has a constant speed, not a constant velocity. While the particle moves with constant speed, the direction it's moving continuously changes.
Ignore the z-component for right now. If x=cos t and y=sin t, what path would the particle follow in the xy plane?
im trying to think about it, it follows a wave, up and down? but can it follow a sin and cos wave at the same time? do they not start from different points? I'm a bit confused
If you're given a value of t, you can calculate what x and y equal and plot that point on the xy-plane. Try doing that for, say, t=0, pi/6, pi/4, pi/3, pi/2, 2pi/3, 3pi/4, 5pi/6, pi.
thanks a million for the replies.
After plotting it out, i think its moving at constant speed,not accelerating around the axis in a circular motion of radius 1?
It's moving with constant speed, but it's accelerating because the direction of the velocity is changing with time.
So now add the motion in the z direction back in. So while the x and y coordinates trace out a circle, the z coordinate increases in time at a constant rate. How would you describe that path?
1. What is the difference between velocity and acceleration?
Velocity is the rate of change of an object's position over time, while acceleration is the rate of change of an object's velocity over time. In other words, velocity tells us how fast an object is moving and in what direction, while acceleration tells us how much an object's velocity is changing.
2. How do you calculate velocity and acceleration?
Velocity can be calculated by dividing the change in position by the change in time, while acceleration can be calculated by dividing the change in velocity by the change in time. Both are measured in units of distance over time squared (such as meters per second squared).
3. What is the difference between average velocity/acceleration and instantaneous velocity/acceleration?
Average velocity/acceleration is calculated over a period of time, while instantaneous velocity/acceleration is calculated at a specific point in time. Average velocity/acceleration gives us an idea of how an object is moving overall, while instantaneous velocity/acceleration tells us how it is moving at a specific moment.
4. How do velocity and acceleration relate to each other?
Velocity and acceleration are closely related because acceleration is the rate of change of velocity. This means that changes in velocity (such as speeding up, slowing down, or changing direction) result in acceleration. Velocity and acceleration also have a direct mathematical relationship, as acceleration is the derivative of velocity.
5. How are velocity and acceleration used in real-world applications?
Velocity and acceleration are used in many real-world applications, such as in physics, engineering, and sports. They are essential for understanding and predicting the motion of objects, such as cars, airplanes, and projectiles. They are also important in designing machines and structures to ensure they can withstand the forces of acceleration. In sports, velocity and acceleration are used to analyze the performance of athletes and improve their techniques.
