Velocity & Mass: Does Speed Increase Gravity?
In summary, the concept of relativistic mass has limited applicability to gravity, and the gravitational field looks different to a moving observer than a stationary one.
neuralnova
When something is moving very fast, does it exert a greater gravitational field, in accordance with its new increased mass?
This is a very common question, asked here many times. You can probably do a forum search and see the previous discussions.
The short answer is no, the concept of "relativistic mass" (the idea that mass increases as you go "faster") has very limited applications, gravitation not being one of them. The gravitational field does look different to a moving observer than a stationary one, but it's not so simple as "faster objects exert more gravity".
See also: https://www.physicsforums.com/threads/what-is-relativistic-mass-and-why-is-it-not-used-much.783220/
I was under the impression that both mass and energy create gravitational fields. If an object with a given rest mass is moving very fast past an observer will it not create a stronger peak gravitational field than a slow moving object with the same rest mass?
Similarly, consider a confined sphere of gas, does it's gravitational field increase with temperature?
P.S. It should be clear that the inertial mass of a confined gas increases with temperature (when the gas molecules move at "relativistic" speeds).
1. How does velocity affect gravity?
Velocity does not directly affect gravity. Gravity is a force that is dependent on the mass of an object and the distance between two objects. However, velocity can indirectly affect gravity by influencing the mass of an object through its kinetic energy.
2. Does the mass of an object affect its velocity?
No, mass does not directly affect velocity. Velocity is determined by the speed and direction of an object's motion, while mass is a measure of an object's amount of matter. However, the mass of an object can indirectly affect its velocity by influencing its acceleration due to the force of gravity.
3. How does speed increase gravity?
Speed, or velocity, does not directly increase gravity. As mentioned before, gravity is dependent on the mass of an object and the distance between two objects. However, an object's velocity can affect its kinetic energy, which in turn can influence its mass and therefore affect the force of gravity.
4. Can an object have a high velocity but low gravity?
Yes, an object can have a high velocity but low gravity. For example, a satellite in orbit around Earth has a high velocity due to its circular motion, but the force of gravity acting on it is relatively low compared to an object on the surface of Earth.
5. Is there a relationship between velocity and mass in terms of gravity?
Yes, there is a relationship between velocity and mass in terms of gravity. An object's velocity can indirectly affect its mass, and therefore influence the force of gravity acting on it. Additionally, the velocity of an object can also affect its gravitational potential energy, which is a measure of its ability to do work due to the force of gravity.
