Homework Help: Velocity and tension problem
  1. Nov 10, 2007 #1
    Hello. Got a few simple physics problems.
    Cannon fires a ball at 30 degrees to the horizontal at a speed of 50 m/s. The cannon is 10 m above the ground. What is the ball's speed when it eventually falls to the ground, using energy conservation! That really threw me off.
    2. Relevant equations
    t = square root of ( 2 times distance / 9.8 m/s^2 )
    = square root of ( 2(10 m) / 9.8 m/s^2 )
    = 1.42 s
    d = 50 m/s (1.42) = 71 m in the horizontal
    3. The attempt at a solution
    So I know v = at, but I don't know the use "energy of conservation" thing.
    A .1 kg ball is at the end of 1.0 m string. It is swung in a verticle circle whose center is 2.0 m above floor. When the string is horizontal and the ball is moving upward, the string suddenly breaks, and the ball reaches a height of 5.0 m. What was the tension in the string the instant it broke?
    Tension = N - mg that I know of.
    From what I know, tension is another cute word for force, right, like T = ma<something theta>, where something = {sine, cosine, etc. }
    Is this an L = mvr kind of problem? I have the mass of ball, velocity of ball, and radius of circle, but don't know how to convert it to tension.
    And I have another question.
    Suppose I have something like.
    ____|____
    |________|
    ____|____
    |________|
    Where | is a string, and the 2 blocks are accelerating upward at 5 m/s^2.
    How do I find the tension at the top of the rope? The blocks are 2.0 kg each, and the rope is .5 kg.
    The force = sum of blocks and rope * acceleration.
    If the whole thing is going upward, do I still take into consideration the 9.8 m/s^2?
  3. Nov 10, 2007 #2
    Shooting Star
    1. You know the ke + pe initially. Equate this to the final ke + pe. It's easy.
    2. Given the initial vertical velo v upward, you can find the h-max and vice versa. So, you get v. Now to find T, equate centripetal force to T.
    3. Motion is due to tension only. Use F=ma. If this is taking place on earth, then add F-mg =ma.
  4. Nov 10, 2007 #3
    PhanthomJay
    You should post each question separately, as it makes it easier to respond. For number one, since only gravity is acting, the conservation of energy principle states that the sum of the initial potential and kinetic energy of the system must be equal to the sum of the final potential and kinetic energy of the system.
  5. Nov 10, 2007 #4
    Okay, so should the initial KE + PE be before the cannon fired, or at peak?
    So I don't have the mass, can I take them out on both sides?
    Initial = final.
    1/2(v^2) + gh = 1/2(v^2) + gh.
    Otherwise I get:
    1/2(m)(80 m/s^2) + m(-9.8 m/s^2)10 m = PE + KE again.
    Okay how do I find initial velocity?
    Alright, thanks.
  6. Nov 10, 2007 #5
    Shooting Star
    Have you solved it or not? I couln't understand that from your thanks.
  7. Nov 10, 2007 #6
    The alright, thanks was just for number 3. :/
  8. Nov 10, 2007 #7
    Shooting Star
    1. final ke + pe at ground = initial ke + pe at cannon. Take mass m. PE at ground is 0.
    2. initial velo v= velo upward when string is horizontal. mv^2/r = T. h is given. From that find v. Then find T.
    Clear?
  9. Nov 10, 2007 #8
    So (1/2)m(50 m/s^2) + m(-9.8 m/s^2)(10 m) = (1/2)m(new velocity^2) + 0
    = 25 m/s^2 * m + -98 m^2 * m/s^2 = (1/2)m(new velocity^2) + 0
    Okay, so I guess I don't need the unknown m, can I get rid of it? By diving it by both sides? And just use:
    1/2 v^2 + gh = 1/2 v^2 + 0?
    Then I'll solve for final velocity.
    Er, so I find v before T. But I don't know T. T = mv^2/r. I have 2 unknowns, v and T.
    Sorry, still a bit lost.
  10. Nov 10, 2007 #9
    Shooting Star
    Somewhat there. The two velocities are different.
    The unit of speed is m/s, not m/s^2.
    The energy eqn is: mv1^2/2 + mgh = mv2^2/2 + mg*0.
    (If you have already found the value of v, then how is it an unknown?)
    You know the height to which it rises. From there you find v. Then plug in the value of v to find T.
    If h is the height to which it rises from where it had vertical velo v, then v^2 = 2gh. Can you do the rest?
  11. Nov 10, 2007 #10
    I don't have velocity.
  12. Nov 10, 2007 #11
    Shooting Star
    You had it. Anyway, now I've given you the formula. Read my last post.
Loading...
