Velocity, IMA/AMA, circuits
In summary, velocity is a measure of an object's speed and direction, while speed only indicates the magnitude of motion. IMA and AMA refer to the theoretical and actual mechanical advantages of a machine, with AMA taking into account real-world factors such as friction. Circuits are paths through which electricity can flow, controlled by switches, and are essential in powering our daily devices. The difference between series and parallel circuits lies in how the current and voltage are distributed. Overall, circuits play a crucial role in our daily lives by providing us with a safe way to use electricity for various tasks.
crl46
Need some help on basic Physics questions... taking teh CSET (I'm a biology major) that involves a lil physics and I'm having brain farts... thanks...
#1)I know that the area under v vs. t curve represents the object's displacement between a certain duration on time... what is the area under a vs. t cute represent?
#2)Car travels 20 km W, then 20 km S... What is magnitude of displacement?
#3)2 vectors of magnitude 20 and 50 km are added. Which is the magnitude of their resultant?
#4) Ramp at loading dock measures 6m long and 1m high. It has an efficiency of 2/3. How much effort force will be required to push a 60 N block of ice up the ramp?
(I know efficiency=AMA/IMA and AMA=load/effort...)
#5) Block and tackle has an IMA=5 and AMA=4. If input work is 100J, how much work is lost in overcoming distance?
(I know IMA=distance of effort/distance load and AMA=load/effort)
#6) Student weighing 4540 N sits on a seesaw 0.60 m from fulcrum. How far from fulcrum on the other side should a child with a weight of 5000 N sit so seesaw is balanced?
#7) Cube of wood with denisty=.780g/cm3 is 10.0 cm on each side. WHen cube is placed in water, what buoyant force acts on wood? density of water=1.00 g/cm3
(I know Fb=density of fluid*V*g...)
#8)Mass of iron weighs 1000 N in air but only 872N when immersed in a fluid. What buoyant force does this fluid exert on the iron?
#9) If the phenomenon of atmospheric refraction did not occur, how mught the apparent time of sunrise and sunset be affected? Answer is sunrise later and sunset earlier... Why?
#10) When placed near the N pole of a permanent magnet, the pointed end of a sweing needle will be...attracted is the right answer. Why? I thiugh it would be repelled.
#11) A simple circuit consists of only 2 identical bulbs. The current in the circuit is 0.25 amps. The sum of the voltages across the bulbs is 24 V. The resistance of a single bulb light would be a) 96 ohms b)48 ohms c) 24 ohms d) 12 ohms
Above ^^^
Above ^^^
#1. x is the area under the curve of v vs. t because v = dx/dt. What's the definition of acceleration?
#2. They form a right triangle, so use the Pythagorean theorem.
#3. Impossible to say. Not enough information. Vector addition takes into account both magnitude and direction. (see #2)
#4. You need to calculate the IMA. Using the efficiency you will get the AMA. Use that to answer the question.
#5. You know input = 100 J. Ideally the output would be what? (Use IMA) But what is it really? (Use AMA). The amount lost is the difference between these numbers.
#6. The torques around the fulcrum must balance.
#7. The wood floats, so the V is only the volume of the block underwater. But a quicker way is to note that because the wood is floating (equilibrium) the bouyant force must be exactly equal to the weight of the block.
#8. The bouyant force is precisely why the weight is less.
#9. The light bends as it enters the atmosphere (Snell's law). Think about the geometry of the problem. When you see the sun setting is it actually above or below the horizon?
#10. The sewing needle has no inherent magnetic field. But bringing it close to the magnet induces one. All the atoms in the sewing needle line up in response. Do you think they will line up with their north or south poles toward the magnet? Remember opposite poles attract, similar poles repel. Once they line up, will the needle be pulled toward or pushed away from the magnet?
#11. What is the total resistance of the circuit? (Hint: use Ohm's law). Since the bulbs are identical (and presumably in series), each bulb will be half the total.
1. What is velocity and how is it different from speed?
Velocity is a measure of an object's speed and direction. Unlike speed, which only gives the magnitude of an object's motion, velocity takes into account the direction of the object's motion as well. For example, a car traveling at 60 miles per hour west has a velocity of 60 miles per hour in the westward direction.
2. What is IMA and AMA and how do they differ?
IMA stands for Ideal Mechanical Advantage, while AMA stands for Actual Mechanical Advantage. IMA is the theoretical advantage gained in a simple machine, whereas AMA takes into account real-world factors such as friction, and is always lower than IMA. In other words, IMA represents the idealized efficiency of a machine, while AMA reflects the actual efficiency.
3. What are circuits and how do they work?
A circuit is a path through which electricity can flow. It is made up of various components such as wires, resistors, and batteries. When a circuit is complete, electricity can flow through it, powering any devices connected to it. The flow of electricity is controlled by switches, which can be opened or closed to interrupt or allow the flow of electricity.
4. What is the difference between series and parallel circuits?
In a series circuit, all components are connected in a single path, so the same amount of current flows through each component. In a parallel circuit, the components are connected in multiple paths, so the current is split between them. Additionally, in a series circuit, the voltage is divided between components, while in a parallel circuit, the voltage across each component is the same.
5. How do circuits help in our daily lives?
Circuits are an essential part of our daily lives as they allow us to use electricity to power our devices and appliances. From turning on lights to charging our phones, circuits play a crucial role in our everyday activities. They also enable us to control the flow of electricity and make it safe for us to use in our homes and workplaces.
