Velocity of bullet
Agent Arlene devised the following method of measuring the muzzle velocity of a rifle (the figure below). She fires a bullet into a 4.064-kg wooden block resting on a smooth surface, and attached to a spring of spring constant k = 164.5N/m . The bullet, whose mass is 7.870 g, remains embedded in the wooden block. She measures the maximum distance that the block compresses the spring to be 9.460cm .
(Figure 1)
http://session.masteringphysics.com/problemAsset/1696765/3/Giancoli7.ch11.p22.jpg
What is the speed v of the bullet?
2. Homework Equations
v=√(k/m)*x
i tried using that equation and different variations but my mastering physics says i'm incorrect.
Answers and Replies
i tried using √164.5/(4.064+.00787) *.0946
i also tried using .5mv^2=.5kx^2
307
Mech. energy is not conserved in inelastic collisions. Use momentum conservation and then use Energy conservation.
i cant tell if the question want the velocity before the collision or after the collision.
418
It says "muzzle velocity". So it is not the velocity after collision.
so then should i not use the equation i did ?
what equation should i use
You should use energy conservation.
The kinetic energy of the bullet before collision = the potential energy of spring after collision
so 1/2mv2=mgh?
The potential energy of the spring not the gravitational potencial energy(which would stay constant as the system is horizontal)
that's right
would x be the compression of the block after the bullets hit?
Yes,right.x would be the compression after bullet hits it.
mass should be in kg or gr?
Wait i think we cant use the conservation of energy here as the mechanical energy is not conserved.Instead we will use conservation of momentum
so then i would use m1v1right?
My answer is coming to be 329m/s.
First ignore the spring and calculate the momentum as
mv =(m+M)v1
Now apply the enrgy coonservation
(M+m)v1^2=kx^2
find the value of v1 and then put it in first equation.You will get the answer.
Related Threads on Velocity of bullet
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
