Calculating Earth's Orbital Velocity from Varying Distance to the Sun
In summary, the conversation discusses determining the minimum and maximum velocities of the Earth in its orbit around the sun, given its varying distance from the sun. The use of conservation of energy is mentioned, as well as the need for another equation to solve for the two unknowns. The equation V_f = (2(2pi^2R_f^2/T^2) + G(M_s/R_f) - G(M_s/R_n))^(1/2) is also mentioned, but using it is incorrect as it assumes the Earth covers a distance of 2piR_f in one year.
  • #36
ahh right those canceled. Sorry that was me being sloppy.
[itex] V_n = (2(\frac{V_n^2 R_n^2}{2 R_f^2} + G\frac{M_s}{R_f} - G\frac{M_s}{R_n})^\frac{1}{2})) [/itex]
and then after plugging in i can go back and solve for
[itex] V_f = \frac{V_n R_n}{R_f} [/itex]
  • #37
You still have sign errors. Remember that gravitational potential energy is negative.
  • #38
So if i flipped the signs on the potential energy i end up with this:
[itex] V_n = (2(\frac{V_n^2 R_n^2}{2 R_f^2} - G\frac{M_s}{R_f} + G\frac{M_s}{R_n})^\frac{1}{2})) [/itex]
would you be able to explain why its negative a little more? I've done other problems with energy like the ones where a rollercoaster goes from the top of a hill to the bottom and you have to find the velocity at the bottom, and in those I used mgy as the potential energy, i still think that's gravitational energy but in those problems it was fine to write it as positive. How can i tell when to change the sign?
Also what process could i have used to use F = MA to rewrite Vf instead of the circular sector approach?
  • #39
You took the potential energy as GMnMf/R. It is zero at infinity, isn't it?
If the Earth gets closer to the Sun, its potential energy should decrease, just as the PE of falling stone on the Earth. And the kinetic energy increases, but the KE is always positive.
If a function decreases from zero, it gets negative. When R decreases the magnitude of the potential energy increases as you divide by R. So there should be a minus sign so as the PE decrease: PE=-GMnMf/R.
You can choose, where is the zero of the potential energy. Near to the surface of Earth it is convenient to chose it zero on the ground. At the top of a hill it is positive then, but decreases when the stone falls down. You can choose the top of hill where the potential energy is zero. Then its gets negative when the stone falls.
ehild
  • #40
ahh ok thanks I think I get it. Aren't there parts of the orbit where potential energy is increasing as the Earth moves farther away from the sun?
  • #41
If the Earth goes farther away from the Sun, its potential energy increases, which means, it becomes less negative. And if it goes very -very far, its potential energy will approximate zero.
ehild
  • #42
You have to recognize that the Earth's orbit is essentially a circle because the eccentricity of the orbit is nearly 0. The Earth's centripetal acceleration is given by ##v^2/\rho##, where ##\rho## is the radius of Earth's orbit, which you can express in terms of ##R_f## and ##R_n##.
  • #43
thank you both so much!
