R Power
- 271
Hello
With what velocity does heat flow in solids? What are the factors on which its velocity depends?
Thnx
Thnx
R Power said:Hello
Thnx
The speed at which any physical disturbance can propagate in a material is the speed of sound. So the time it takes for the temperature to start changing at the other side would be based on the speed of sound.R Power said:Take an iron rod and heat it from one end. Put each one of your hands at the respective ends of rod. You feel instantly feet hotter at the end you heat but it will take some time for you to feel hotter at the other end. This time is the time heat has taken to flow. That means heat has a flow velocity. It is this velocity I am talking about and not of free electrons on anything. I was just wondering why aren't any articles or texts written on velocity of heat.
google or wiki 'thermal diffusivity'
it is the ratio of conductivity to volumetric heat capacity
basically, it tells you how fast heat is conducted through a material
Yes, I am asking the first question.Consider the following two questions:
1. If heat is applied to one end of a metal bar, how long does it take before the other end feels *any* change in temperature?
2. If heat is applied to one end of a metal bar, how long does it take before the temperature at the other end rises by 1C?
So, speed of sound is the answer. Thnx to everyone.The time for an infinitesimal temperature increase will be the length of the bar divided by the speed of sound.
Studiot said:It implies that the temperature rise at the remote end is independent on the shape of the bar, which is in direct contravention of Fourier's Law.
How much high rate? Is there a certain value you know for a given material? This is what I want to enquire to which I have been answered with speed of sound.The initial small change moves at a very high rate while the main part of the change lags far behind.
R Power said:Yeah, thermal diffusivity tells us how fast heat diffuses or flows through a material. I think this is answer to my question but it contradicts Russ' answer of speed of sound.
Chestermiller said:You need to examine solutions to the transient heat conduction equation.
AlephZero said:But first, you need to decide if the usual heat conduction (or diffusion) equation is just a nice approximate model of the physics. The conduction equation is parabolic PDE, and its solutions say that effects can propagate instantaneously over any distance in space, however large. I think Mr Einstein might have a problem with that
The three main factors that affect heat flow velocity in solids are thermal conductivity, temperature gradient, and the thickness of the material. Materials with higher thermal conductivity, steeper temperature gradients, and thinner thickness will generally have a higher heat flow velocity.
Thermal conductivity is a measure of how well a material can conduct heat. Materials with higher thermal conductivity will generally have a higher heat flow velocity, as they are able to transfer heat more efficiently.
The temperature gradient is the change in temperature over a distance. The steeper the temperature gradient, the higher the heat flow velocity will be. This is because a greater temperature difference between two points in a material will result in a faster transfer of heat.
The thickness of a material also plays a role in heat flow velocity. Thicker materials will generally have a lower heat flow velocity, as the heat has to travel a greater distance to be transferred. Thinner materials will have a higher heat flow velocity, as the heat has a shorter distance to travel.
The heat flow velocity in solid materials is an important factor to consider in various industries, such as construction, engineering, and materials science. Understanding the heat flow velocity can help in designing more efficient and effective heat transfer systems, as well as predicting the thermal performance of materials in different environments.
