• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Velocity of object
Hello, i have to work out the velocity of a catapult which i had to do for my AS Quality of measurement coursework where I'm trying to find the optimum angle of launch.
1. Homework Statement
A ball is fired from a catapult 0.5m above the ground, the ball hits the ground 1.45m away, the angle of launch is 45°. Calculate the velocity of the ball.
2. Homework Equations
v^2= u^2 + 2as
3. The Attempt at a Solution
Attempted it by plugging numbers into that equation but comes up with 37.6 m/s, whilst watching the catapult fire it took a few seconds to land so it couldn't be that fast, although after using Time = Distance/Speed it appears to be 3.9s which could be right but I'm not sure. Am I using the wrong equation i need to compare this to other angles but not sure what equation to use with angles.
Sorry, are you trying to find out the optimum angle of launch? Because you stated an angle in section one, the known data.
I was using 45° as an example, whilst doing the experiment I measured the distance travelled for 11 angles at 5° intervals from 20° to 70°. As 45° is the optimum angle excluding air resistance I'm going to work that one out first and compare to other angles. Should of included more detail. :smile:
How did you get the to answer of 3.9 seconds and 37.6 ms-1? From what you have given me in section one (the known data) I can only find the horizontal distance and the launch angle, and I cannot understand how you find your given answer from that. Is there a missing piece of data that you might have forgotten?
I worked it out for myself, noticed i was making a huge error by putting the displacement in cm instead of metres, silly me. :rofl:
Related Threads for: Velocity of object
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
