Homework Help: Velocity of satellite
  1. Jan 11, 2009 #1
    A satellite is in a circular orbit about the Earth at a distance of one Earth radius above the surface. What is the velocity of the satellite?
    3. The attempt at a solution
    I assumed the orbital radius was twice the radius of the earth so
    GMearth/r= velocity
    but that leaves me with a very small velocity...
  3. Jan 11, 2009 #2
    G01
    Can you show your answer and your work? If you do have a mistake, I can't find it without seeing both.
  4. Jan 11, 2009 #3
    well since I assumed orbital radius was 2Eradius, then
    (GMearth/r)^.5= v
    I plugged in (6.67*10^-11(5.98*10^24)/6.37*10^6)6.5= 7913.048m/s
  5. Jan 11, 2009 #4
    G01
    Why are you multiplying by 6.5? Also, you never doubled the radius when you plugged in the numbers. According the the formula you give, which is correct, the velocity should be:
    [tex]v=\sqrt{\frac{GM}{2r_e}}[/tex]
    Plugging in the numbers you give, I get an answer around 5000m/s.
  6. Jan 11, 2009 #5
    why do you double the radius?
  7. Jan 11, 2009 #6
    G01
    You said it yourself before. The orbital radius is twice the radius of Earth. In your formula, you used the radius of Earth, not double the radius of Earth.
Loading...
