• Support PF! Buy your school textbooks, materials and every day products Here!
Velocity of water across depth
  • Thread starter fonseh
BvU
2019 Award
12,889
2,967
4,050
can you show the graph of shear stress ? I'm very confused now ... Do you mean the shear stress increases from zero at the top down to the bottom ?
Yes.
4,050
In the Wiki article on viscous laminar flow in a tube, they do an axial force balance on the shell of fluid between radial locations r and r+Δr. An easier way to analyze the problem is to do an axial force balance on the plug of fluid between r = 0 and arbitrary radial location r:
$$\pi r^2\Delta p+2\pi r L\tau_{rz}(r)=0$$where ##\Delta p## is the pressure drop between the inlet and outlet of the the section of pipe under consideration, L is the axial length of the section of pipe, and ##\tau_{rz}(r)## is the shear stress the radial surface of the plug (i.e., at constant r in the z direction). From this equation, we get that:
$$\tau_{rz}=-\frac{\Delta p}{2L}r$$
This tells us that, for steady flow in a pipe, the shear stress varies linearly with radial distance from the axis.
Can you point out which part of the wiki article shows that the velocity profile of water across depth is parabolic shape ?
4,050
The entire section Putting It Together, culminating with the next-to-last equation which gives the parabolic velocity profile.
  • #31
529
Where do you get this equation actually ?
  • #32
19,805
4,050
It's just a force balance (you remember, like in freshman physics). Please show us what you think the free body diagram looks like.
  • #33
529
i know that A = pi(r^2) , so dA = 2pi(r)dr , so in $$\pi r^2\Delta p+2\pi r L\tau_{rz}(r)=0$$ , why there is L ? shouldnt it $$= 2\pi r \tau_{rz}(r)=0$$ only ?
  • #34
19,805
4,050
There are pressure forces on the two ends that have to be balanced by the viscous frictional (tangential) force.
  • #35
19,805
4,050
  • #36
529
Can you explain further how to get 2\pi r L\tau_{rz}(r) ??
  • #37
529
why there is L ?
  • #38
19,805
4,050
Related Threads for: Velocity of water across depth
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
